Thread: Help brake and clutch pedal PLAY
Results 1 to 10 of 15
  1. Help brake and clutch pedal PLAY
    Jul 2007
    chepstow
    I have a 2001 passat se tdi and if i rest my foot on the clutch and brake pedals at the sane time there is some movement (play) between the two is there a way to fix this and what do I need
    135 Post(s)
    2038 Post(s)
    You need to get that inspected for any loose fastenings.
    Jul 2007
    chepstow
    i have had a good look and everything is done up
    135 Post(s)
    2038 Post(s)
    I work on 3B Passats all day long and I have never seen a pedal box problem. PM me your chassis number if you don't mind.
    Mike McKinstry Guest
    Hi-
    I have same problem with 51 plate Se tdi 130 -was there any resolution to this issue?
    135 Post(s)
    2038 Post(s)
    Err, no - I wish I could come across one to see what causes it.
  7. Re: Help brake and clutch pedal PLAY
    Jul 2007
    Mines The Same Too. 53 Plate Tdi Se. Doesnt Seem To Be Causing Any Problems Though.
  8. Re: Help brake and clutch pedal PLAY
    Feb 2007
    i swear that my brake pedal is the problem regarding the brakes locking on and me sitting in the middle of the road, unable to move anywhere until i manage to release the pedal with a big sounding "click" When i have had to carry out a hard stop.
    crasher, have you had this fault before 51 plate 130 BHP sport?
    Fozzie!
  9. Re: Help brake and clutch pedal PLAY
    135 Post(s)
    2038 Post(s)
    Many times. It is becoming a huge problem with the A4, A6 and Passat due to the plenum chamber under the windscreen filling up with water. What happens is the servo can have a very tiny air leak and so if it sits in water it sucks water into the servo which then goes rusty inside. Have you had water ingress problems?
  10. Re: Help brake and clutch pedal PLAY
    Jul 2007
    Chesterfield Area
    My 2002 model B5 has been like that from new. Never worried me.
  1. High Clutch Pedal
    By Jabez in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-06-2010, 03:26 AM
  2. clutch pedal
    By frank99jc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2008, 09:47 AM
  3. Thud when releasing clutch pedal
    By Mark A in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-11-2007, 07:47 PM
  4. Vibrating Clutch Pedal
    By JasonC in forum Passat - Archive Topics
    Last Post: 22-01-2007, 01:40 AM
  5. Sticking Clutch Pedal
    By Sesame in forum Passat - Archive Topics
    Last Post: 31-05-2006, 11:39 PM
