Thread: Oil Leak.....Maybe Turbo Oil Line
  1. Oil Leak.....Maybe Turbo Oil Line
    Sep 2007
    Plymouth
    My machine (2003 A6 1.9td AWX Avant) is shedding some oil from offside front. Making a mess on the road!
    I know it's not the intercooler pipes, having dealt with that issue before. Looking from above the engine everything looks dry, underneath though is soaked with oil and I cannot see where it's coming from!
    I've had the car on a mates lift, heavily degreased the area so it was really clean, and watched while the engine was running for several minutes and could not see any spray/mist of oil. New oil was seeping though.
    The only point I seem to be able to narrow it down to is the turbo oil return line. My question: is the oil return line subject to failure on these?
    2003 A6 1.9TDI PD Avant SE 359,000 miles
    Cannondale Road Bike
    Yeti ASR SL Mountain Bike
    9ft 4inch Surfboard (two of)
  2. Re: Oil Leak.....Maybe Turbo Oil Line
    Check the banjo joint feed to the turbo. The return line is of the scavenge type so there is no pressure unless you have a breather blockage. Regards Peter
  1. 2004 1.8t 190 s-line oil leak?
    By rosss6 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-03-2011, 04:45 PM
  2. audi A6 s-line 2007 model OIL LEAK PROBLEM
    By LJOPI in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-06-2009, 12:31 PM
  3. turbo oil leak. or could it be something else??
    By gemmell88 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-04-2008, 04:18 PM
  4. Turbo oil leak
    By Buzzlb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2008, 12:06 PM
  5. Golf Turbo Oil Leak
    By nobbythecat in forum Golf MK4 - 1999 - 2004
    Last Post: 10-01-2008, 09:16 AM
