Thread: Help needed
  1. Help needed
    May 2010
    Devon England
    Hi all, im in need of some advice, since i had my R32 cluster fitted ive had the ESP light on all the time (adaption settings???) so ive borrowed Robs VCDS lead and done a complete scan, which i will add below, now the fault in the ABS wont clear down, ive tried doing the basic setting but it wont let me, i hope im doing something wrong lol
    any help would be great
    heres the scan
    Chassis number changed for safety
    Friday,03,June,2011,21:51:12:34667
    VCDS Version: Release 10.6.3 (x64)
    Data version: 20101206
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 7D
    VIN: WVWZZZ1KZ4W13ECFC Mileage: 216910km/134781miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    37-Navigation -- Status: Cannot be reached 1100
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 B HW: 028 101 147 8
    Component: R4 1,9L EDC G000SG 5645
    Revision: 12345678 Serial number: VWZ7Z0D9633781
    Coding: 0000071
    Shop #: WSC 00000 028 00001
    VCID: 226524438449
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0021121
    Shop #: WSC 01279 785 00200
    VCID: 3A55FC230CD9
    2 Faults Found:
    00810 - Sensor 1/2 for Brake Pressure
    005 - No or Incorrect Basic Setting / Adaptation
    01423 - Lateral Acceleration Sensor (G200)
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 CC
    Component: Climatic PQ35 080 0201
    Shop #: WSC 00000 000 00000
    VCID: 67F375572FEB
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 1K0 937 049 S HW: 1K0 937 049 S*
    Component: Bordnetz-SG 1.0 H30 0704
    Revision: 00030000 Serial number: 00000000621926
    Coding: E48B8F0600041800001400001400000000
    VCID: 3FA38D3717FB
    Part No: 1K2 955 119 B
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00000
    Part No: 1K0 955 559 M
    Component: RegenLichtSens 005 0605
    Coding: 00217125
    Shop #: WSC 00000
    2 Faults Found:
    00975 - Heated Rear Window (Z1)
    006 - Short to Plus - Intermittent
    01493 - Bulb for Blinkers; Front Left (M5)
    012 - Electrical Fault in Circuit - Intermittent
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
    Component: 02 AIRBAG VW8 022 0600
    Revision: 05022000 Serial number: 0033JD0B6JZN
    Coding: 0012338
    Shop #: WSC 01268 785 00200
    VCID: 2D7FC77FCD97
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
    Component: J0527 036 0070
    Coding: 0003022
    Shop #: WSC 00066 000 00000
    VCID: 75CF2F1F6547
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K6 920 972 E
    Component: KOMBIINSTRUMENT VDD 4312
    Coding: 0007203
    Shop #: WSC 08055 444 84943
    VCID: 3449D21B2EBD
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 C HW: 1K0 907 951
    Component: Gateway H08 0080
    Revision: 08 Serial number: 260010431806DB
    Coding: 3D0F0B48070003
    VCID: 27733557EF6B
    1 Fault Found:
    01300 - Control Module for Navigation with CD-Rom (J401)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 254
    Reset counter: 47
    Mileage: 212838 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 22:07:54
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VDD 4312
    VCID: 3449D21B2EBD
    2 Faults Found:
    01176 - Key
    008 - Implausible Signal - Intermittent
    02241 - Engine Control Module; Immobilizer Data not Adapted
    000 - - - Intermittent
    Address 37: Navigation
    Cannot be reached
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
    Part No: 1K0 959 701 E
    Component: Tuersteuergeraet 09 0116
    Coding: 0000052
    VCID: 3041DE0BDAA5
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.070 H07 1806
    Shop #: WSC 02069 000 90108
    VCID: 354FEF1F25C7
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 T
    Component: 0W KSG 0560
    Coding: 81E802087F2D8505485BC61000
    Shop #: WSC 00046 412 819200
    VCID: 41A78BCF610F
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Part No: 1K0 951 177
    Component: Innenraumueberw.004 0101
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Coding: 0000052
    VCID: 3147DB0FD1AF
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 5M0 035 186 A
    Component: Radio GR0 015 0019
    Revision: 0001503S Serial number: VWZ2Z2E1109355
    Coding: 0040400
    Shop #: WSC 01392 785 00200
    VCID: 2A75CC63FC79
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    VCID: 2C79CA7BF68D
    Also in the highline i dont have the lights and vision setting and read somewhere that it would prob need to be activated, can someone tell me how to do it please
    VCDS HEX+CAN CODE READING AND RECODES
    OWN A MK5 GOLF TDI JOIN THE GROUP https://www.vwaudiforum.co.uk/forum/group.php?groupid=23
    2004 mk5, Viezu 140bhp Re-map, GTI front bumper, side skirts, GTI 18in rep wheels, Jamex coilovers, R32 speedo cluster, MFSW, White Roose Motorsport coolant hose's, GTTDI interior, centre consol armrest and ipod dock, leather handbrake lever
  2. Re: Help needed
    May 2010
    Devon England
    Ok, now dont ask me how but ive managed to sort the ESP out (still dont know lol) i went through the long code helper and all of a sudden the light went off, WINNER
    now ive also got my coming home lights working again but i havent got lights and vision on my highline (still need help on that one)
    while i was sat in the car playing with the long code helper for loads of different things i have set it so the locking beeps the horn as well as flash the indicators SWEET
    got a bit of a head ache so calling it a night will play more tomorrow
    one other thing ages ago i asked if i could make my brake lights FLASH under heavy braking and from what ive seen on the rosstech pages it is poss so i will have a go at it tomorrow
  3. Re: Help needed
    Jan 2008
    Kinross Scotland
    HI reading your scan, I see that block 7D Aux heater is fitted, what is that ? I know in Canada and Nordic countries that is an option, but never seen it on a UK Car or, seen it offered as an option.
    Brake lights flashing under heavy braking I think I read something in the manual that this was a feature that is actvated as normal.
    Lights and vision on the highline, do you mean dash lights and MFD display ?. over on VW vortex and mygti.com there is several referances to this.
    Tiguan 2.0 4Motion 140PS 01/07/2013
  4. Re: Help needed
    May 2010
    Devon England
    Quote Originally Posted by richard@thebrae View Post
    Hi mate, the Aux heater would need to be activated, basicly from what ive seen you can program it to warm the inside of the car to a set temp, so if you left for work at 8am you can program it to warm the car to say 16c from say 7:50 so its not cold, never used it tbh lol
    The lights and vision is in the MFD display so you can enter the menu for it and adjust the brightness of the puddle lights, how long the coming home lights stay on for how long the main interior light stays on for that sort of thing, thank you for the link will have a read thro the threads on there
  5. Re: Help needed
    May 2010
    Devon England
    Well have now found out why i have no lights and vision, i have a low CCM and CECM so i need to get the HIGH ccm and cecm so i can get it to work
    if anyone has one please email me
  1. Help needed please :)
    By iparkes in forum Golf MK4 - 1999 - 2004
    Last Post: 13-09-2010, 03:58 PM
  2. Help needed!!
    By veedubbora07tdi in forum Bora - 1998 - 2005
    Last Post: 30-07-2008, 02:10 PM
  3. help needed
    By hel in forum New Member Introductions
    Last Post: 14-04-2008, 01:46 PM
  4. S3 help needed
    By johntal in forum Audi A3 - Archive Topics
    Last Post: 20-02-2008, 08:44 AM
  5. help needed
    By kharva007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-05-2007, 06:36 PM
