Thread: 1.8 T Oil Pump / Strainer Change - What mileage did you do it ?
  1. 1.8 T Oil Pump / Strainer Change - What mileage did you do it ?
    Dec 2006
    1.8T Oil Pump / Strainer Change?
    Question for the 1.8T owners..
    At what sort of mileage did you change the oil strainer and or oil pump ??
    Rick
  2. Re: 1.8 T Oil Pump / Strainer Change - What mileage did you do it ?
    132 Post(s)
    1980 Post(s)
    If you don’t know it has been done I suggest you just do it and make sure you apply the sealant very carefully, yesterday I did one that had suffered a blockage due to excessive silicon being used and it was not the first time I have seen that. If you find the sides of the sump are covered in sludge, paint stripper is the ideal way to remove it. The sump in the picture was ditched when I took it off.
  3. Re: 1.8 T Oil Pump / Strainer Change - What mileage did you do it ?
    Dec 2006
    Cheers Crasher,
    Think im going to plan for the dealer to do it as the same time as an Oil change as I am wanting to keep the car within the network as its a fine example and has been to the dealer every 10k miles from day one, plus the oil change is due in 1k miles.
    How much time would you expect / normally quote (time) for this type of job ?
    Rick
  4. Re: 1.8 T Oil Pump / Strainer Change - What mileage did you do it ?
    132 Post(s)
    1980 Post(s)
    2 hours if cleaning out the old sump, it maybe worth asking them to fit a new sump due to their propensity for stripping their threads on the drain bung and they are not going to be keen on cleaning out the old one, a dealer history is not all it is cracked up to be…
  1. Replies: 301
    Last Post: 07-08-2017, 11:45 PM
  2. Pela oil change pump
    By batteryman in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2012, 12:16 AM
  3. 2.6 V6 oil strainer
    By chris.r. in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 05-05-2010, 04:54 PM
  4. V6 2.6 oil pump strainer
    By chris.r. in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2010, 01:17 PM
  5. Blocked oil strainer-Anyone help?
    By les miserables in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-07-2007, 10:30 PM
