Thread: is it possible to remove the airbag light?
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: is it possible to remove the airbag light??
    Aug 2011
    Meath
    Your diagnostic acumen is astounding as are your powers of lateral thinking! There is an easier way to stop the brake light flashing ijust clean the connectors where they meet the brake pads. You could also bridge the connection where it connects to the brake pads with a paper clip but perhaps pulling and dismantling the dash is easier?
    Quote Originally Posted by davidson4301 View Post
    Hi all,I have just done mine (not airbag but break pad light) as it was faulty and kept flashing.
    To remove the cluster.
    1. Pull steering wheel all the way down and out
    2. Pull plastic/leather clip at bottom of cluster gently towards you.
    3. You will see 2x torq screws right underneath the cluster. Remove these.
    4. Pull whole cluster towards you. This might be tight but be patient it will come eventually.
    (don't worry there is no cable or anything at the back of the cluster so nothing to break)
    5. Remove the outer casing by releasing the 6 clips.
    6. **Take note of needle location(or take a pic). Gentle pull needles out. If the don't come, just wiggle anti clockwise.
    7. Gentle take out dials, and then you will see the L.E.D's.
    8. Tape over, smash or whatever any warning light you don't like.
    9. Refit in reverse. Simples
    2 1 0
  2. is it possible to remove the airbag light??
    Oct 2010
    Here And There
    hmm, i wonder how the op is going to get an mot, now that airbag lights are part of it. no airbag light showing upon startup = fail.
    the brake warning light, ok so that won't fail, but surely its better to fix the fault than remove the bulb ?
    In Northern Ireland, the new mot cannot and does not fail you if you have NO airbag light on at all ( bulb taken out ) but will fail you if its on after the car is started. Stupid, I know but thats the government for you !
  3. Re: is it possible to remove the airbag light??
    Aug 2012
    Newquay, Cornwall
    The new MOT guidelines in the UK means that the system has to go through its self test, i.e they are looking for the bulb to come on and then go off. If this dose not happen then it is a Failure. This goes for ABS, Airbag, ASR etc.
    The problem is that if the light is staying on then surprisingly its trying to tell you that there is a fault with the system. Cusford I suggest that you invest in front seat dummy airbags as suggested earlier this will fool the system into thinking that an airbag unit is there and will extinguish the warning light.
  4. is it possible to remove the airbag light??
    Oct 2010
    Here And There
    Quote Originally Posted by A4 Lad View Post
    Just quoting myself to say that I see it every week now. Cars WITH airbag lights disconnected, tin foiled over behind the dash or simply siliconed over and PASSING MOT. If its on, it will fail.... If its gone, it will pass
  5. Re: is it possible to remove the airbag light??
    Aug 2011
    Meath
    If the airbag light is on because the seats were changed and the replacement seats don't have airbags You can put a 5p resistor into the airbag plug and clear the fault. The light should then come on and go out
  6. Re: is it possible to remove the airbag light??
    Aug 2012
    Newquay, Cornwall
    This is taken from the UK MOT Testers Manual
    5.4 Supplementary Restraint Systems (SRS)
    Reasons for rejection:
    A Supplementary Restraint System Malfunction indication lamp that is:
    1/ Inoperative
    2/ Indicating a system Malfunction
    3.4 Anti Lock Braking and Electronic Stability Control
    A warning lamp:
    1/ Is missing
    2/Does Not Illuminate
    3/ Indicates a Fault
    4/ Does Not follow the correct sequence of opperation
  7. is it possible to remove the airbag light?
    #17
    Oct 2010
    Here And There
    Just saying what I see matey..... I work on them for a living and have seen at least 10 cars over the last few months get through MOT with NO bulb lighting up. I am not saying you are wrong but maybe MOT in Norn Iron is different OR they are complete idiots in our government run centers ( probably the later of the two lol )
  8. Re: is it possible to remove the airbag light?
    #18
    Pembrokeshire
    22 Post(s)
    if there is no airbag light to be seen, then the tester has to look for signs the car has airbags fitted. the steering wheel would say 'srs' or something like that but may have been fitted later to a non airbag car. same goes for the dash as well, if that says 'srs' on the passenger side. so basically, to have a fail for no airbag light the tester would need to prove thats it does have airbags and the system isn't working, or have it written on his test sheet that airbags are fitted.
  1. airbag light
    By stevoo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-06-2010, 08:55 PM
  2. Please Help Engine Light & Airbag Light stay on
    By sobberz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-06-2010, 07:27 AM
  3. Question How do I remove airbag steering wheel?
    By kktm in forum Golf MK3 - 1993 - 1999
    Last Post: 06-09-2008, 12:25 AM
  4. Please Help Airbag light
    By Big John in forum Golf Plus
    Last Post: 01-09-2008, 07:42 PM
  5. how to remove my airbag
    By gt07 in forum Golf MK5 - 2004 - 2009
    Last Post: 24-06-2008, 09:34 PM
