Thread: Steering - Rubbing Sound
  1. Steering - Rubbing Sound
    Mar 2009
    Our Q7 has had this for a couple of years and Audi have never managed to diagnose a fault.
    When the car is moving slowly and the steering wheel is being turned, we can intermittently hear what I described as like a low noise that almost sounds like a plastic/ nylon rubbing sound.
    Anyone help please because the car is under warranty and if someone has an idea, I'll get the garage to investigate...
  2. Re: Steering - Rubbing Sound
    Aug 2007
    Hi, I have the same problem. Did you ever manage to find a solution?
  3. Re: Steering - Rubbing Sound
    Mar 2009
    Quote Originally Posted by djbcatlett View Post
    No, asked the Audi garage to check it and they say they can't find a fault. The noise still prevails sometimes though.
  4. Re: Steering - Rubbing Sound
    Dec 2008
    Mine does the Same. just haven't had time to take a look
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Could it be the slip ring behind the steering wheel? Do a search on Slip Ring in the A6 C6 forum - one of the threads about it on there links to a video on YouTube where you can hear the noise. This will tell you if it's what you are hearing in your Q7
    Cheers!
    MF
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  6. Steering - Rubbing Sound
    Aug 2007
    I asked Audi to look at this and they said that it caused by the steering oil and there is a tech note out on it. They said that the oil needs changing for a different type!?
    Sent from my iPad using Tapatalk HD
  7. Steering - Rubbing Sound
    46 Post(s)
    I'm sure after nearly a year the OP has the problem sorted lol
  1. Strange knock/creak/rubbing from steering
    By audidoit in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-08-2010, 06:02 AM
  2. Please Help Steering Wheel Rubbing on Cowling
    By nc35 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-07-2010, 07:26 AM
  3. Please Help Annoying rubbing sound
    By SKINNYSEAND in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-11-2009, 07:47 PM
  4. Rubbing sound
    Last Post: 09-05-2009, 05:29 PM
  5. Passat rubbing sound
    By simbob3000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-04-2009, 11:04 AM
