Thread: 2002 passat car alarm
Results 1 to 10 of 11
  1. 2002 passat car alarm
    Dec 2010
    leicester
    Hope anyone can help. I've got a vw passat 2002 and the alarm keeps going off. It's now 1230 am and i going through the manual desperatly tryng to turn the thing off without leaving the doors unlocked.
    Is there a fuse that i can remove that just turns off the alarm but not the other features.
    Tosh1
  2. Re: 2002 passat car alarm
    Apr 2009
    Hello, still awake? lol
    Theres a siren mounted beside the battery, you can disconnect that until you sort-out whats
    triggering the alarm. It might be the rechargeable batteries in the said siren that need renewed,
    they only have a certain life-span of X amount of charging cycles, and when they die the alarm
    system thinks that someone is fiddling with it.
    Regards
    Jim
  3. Re: 2002 passat car alarm
    Sep 2009
    Wellingborough
    fuse 14 is the one to remove, on the side of the dash with the drivers door open
    The cause could be the CCM so check under the passenger carpet for damp, or a dodgy switch in a door, boot or bonnet. good luck there is plenty of advice on here if you search for alarm or ccm problems.
  4. Re: 2002 passat car alarm
    ashbourne
    I have got the same problem with my 2001 passat. You can lock the car, without the alarm, by reaching through the passenger door and pressing the internal locking rocker switch.
    This is a job for the front seat passenger, they love doing it!
  5. Re: 2002 passat car alarm
    ashbourne
    Ude 65, are you sure that fuse 14 will cure the problem?
  6. Re: 2002 passat car alarm
    Sep 2009
    Wellingborough
    removing the fuse stops the alarm going off, but you still need to find the fault.
  7. Re: 2002 passat car alarm
    Dec 2010
    leicester
    I have noticed that my passenger side carpet is soaking wet. My alarm has been going off but I have been using the passenger side door to close this. Could somebody please place a link on this forum to where I can look.
    Thank you
  8. Re: 2002 passat car alarm
    S Wales - no, not save the whales!
    This is your problem - many have had it at some point (me included but I learned from here)
    You'll find out exactly what to do at this link:
    Interior leaking | veedoubleu dot com
    2004 Passat Estate 1.9 TDI SE 130
  9. Re: 2002 passat car alarm
    Jan 2021
    Forsbrook, UK
    Quote Originally Posted by Ude 65 View Post
    Hi guys, I know this is an old thread but I am having the same problem, my alarm is going off randomly and I would like to disable it. I tried to find fuse 14 in the fuse dashboard in the side of the driver and I couldn't find that number. My Wolkswagen model is a Passat Station Wagon 2002. Any ideas where I can find that fuse? I tried everything to disable the alarm but nothing works, help!!!
    Many thanks for your help!
  10. Re: 2002 passat car alarm
    Dec 2008
    14 Post(s)
    As mentioned above.........is your passenger side carpet wet? Also check plenium chamber (where your battery is) for standing water. If answer to either is yes then search on here for CCM problems and cures.
  1. Location of alarm siren on 2002 Passat sedan
    By sandyberger243 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2009, 01:51 PM
  2. Please Help Alarm/key fob problem 2002 passat
    By andy2586 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-12-2008, 10:57 AM
  3. Intermittent Alarm 2002 Passat Estate!
    By EddyStone in forum Passat - Archive Topics
    Last Post: 20-11-2007, 02:39 PM
  4. Passat Car Alarm Fault
    By saucebury in forum Passat - Archive Topics
    Last Post: 06-08-2006, 03:21 PM
  5. Passat car alarm
    By Martin Linklater in forum Passat - Archive Topics
    Last Post: 16-01-2006, 02:07 AM
