Thread: dashboard airvent removal
Results 1 to 10 of 19
  1. dashboard airvent removal
    Mar 2010
    salisbury wilts
    hi i just got hold of some new dash airvents which are chrome surround and illuminated. can anyone tell me the easiest way to remove them. cheers
  2. Re: dashboard airvent removal
    Feb 2009
    Leicester, UK.
    Sorry can't help with removing them but will be interested in the finished outcome - pics please! Did you get them from fleebay?
    MY07 B6 Passat 140 SE TDI
  3. Re: dashboard airvent removal
    Mar 2009
    York
    the two at the left and right of the dash are easy - prise a flat-head screwdriver underneath them and lift gently. They'll pop out and pop back in again. The middle one I've heard is difficult, as it\s easy to break clips on removal. It'll be the same technique, but maybe very carefully.
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  4. Re: dashboard airvent removal
    DSG4ME Guest
    Might help to take the radio out and open the tray doors and have a nosey behind before you go any further.
  5. Re: dashboard airvent removal
    Mar 2010
    salisbury wilts
    right thanks for all your replys. yep as said left and right were easy used butter knife center was a bit harder but came out with no damage. had to take radio out anyway to wire vents up for illumination. pics below for finished result. got em off a seller on fleabay £70 delivered from spain OEM and new not chinese copies. got my old ones spare now so they will be on fleabay later.
  6. Re: dashboard airvent removal
    DSG4ME Guest
    Looks good.
  7. Re: dashboard airvent removal
    Feb 2009
    Leicester, UK.
    They look great! Any pics at night yet?
  8. Re: dashboard airvent removal
    Mar 2010
    salisbury wilts
    only put them in this morning will add night shot to the pics later
  9. Re: dashboard airvent removal
    Apr 2010
    Ashford, Middlesex
    Where do they wire up to manity?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  10. Re: dashboard airvent removal
    Mar 2010
    salisbury wilts
    there are plugs attached to the back of them but my car wasnt fitted with the wiring loom to plug them into. so i just wired them to the + illumination wire that goes into the headunit and used the - from headunit aswell. works fine come on when i switch my lights on.
  1. dashboard trim removal
    By ray38carp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2010, 05:50 PM
  2. Dashboard removal
    By manic33 in forum Polo - Derby - Lupo - Fox
    Last Post: 19-01-2010, 01:44 AM
  3. Dashboard Removal
    By elliottj in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-10-2008, 02:37 PM
  4. Dashboard trim removal?
    By talmanja in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-08-2008, 09:45 AM
  5. dashboard removal
    By jaybee2429 in forum Touran - Sharan - Caravelle
    Last Post: 13-11-2007, 01:06 PM
