Thread: Some advice in driving a turbo car
  1. Some advice in driving a turbo car
    warp_speed Guest
    Ok, I'm looking for some driving advice. I've moved from a 3.0V6 to a 2.0TFSI both engines have the same power and torque, but I've noticed that the 3.0V6 has more instant power when you planked your foot down from low down the rev range. With the 2.0T I have to make sure the engine has a high rev before I get the same kick from the car, does that sound right? I've never driven a car with forced induction before so I'm a bit of a novice, advice would be appreciated.
  2. Re: Some advice in driving a turbo car
    Mar 2007
    nr Gloucester
    Its called turbo lag. When you 'plank' your foot, it takes some time for the turbo to spool (normally a few tenths of a second) before you get the thwack from the turbo.
    The reason the na 3.0V6 has the immediate power is becuase it has higher torque lower down the rev range than the turbo version.
    Audi A6 (C7) 3.0 BiTDi Black Edition 2016
  3. Re: Some advice in driving a turbo car
    Jul 2010
    Bracknell
    On mine I find the power tends to come in gradually rather than a sudden surge (except perhaps 1st gear) unless the turbo happens to already be spinning at a good speed.
    Approaching roundabouts and changing down gears and using a little engine braking together with the brakes helps to keep the revs up compared to engaging the clutch and letting the revs drop to idle. This helps when accelerating when you can see the roundabout etc... is clear.
    Also give the turbo a little time to cool down if it has been used heavily. Natural driving does this anyway but if you are going along a motorway and then pull into services slow down for a mile before the turning or leave the engine idling before turning it off after parking. This stops the turbo cooking the oil.
  1. Brand new car vs. my wifes driving.
    By smorg00 in forum Golf MK6 - 2009 - 2013
    Last Post: 11-03-2011, 11:40 AM
  2. Driving A Proper Car Now!
    By D2NY G in forum New Member Introductions
    Last Post: 31-01-2011, 04:39 PM
  3. Help! Car died while driving, ECU? Speed Sensor?
    By dmollo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2009, 01:23 PM
  4. Golf GT Sport TDi Driving School Car !
    By on board traini in forum Golf MK5 - 2004 - 2009
    Last Post: 03-06-2008, 06:59 PM
  5. Driving your car when cold
    By loki in forum Chat - Anything with wheels
    Last Post: 10-11-2007, 10:25 PM
