Thread: Coolant Temp Sensor
Results 1 to 10 of 32
  1. Coolant Temp Sensor
    Mar 2011
    Croydon UK
    Hi Guys, My Coolant Temp sensor is intermitant ( fluctuates between 50 & 90 when car has been running for a while) , can someone tell me where this is located in the engine bay? hopefully will be able to get a new one & fit it at the weekend.
    Audi A4 B6 TDI 130
  2. Re: Coolant Temp Sensor
    Jan 2009
    Birmingham
    36 Post(s)
    Ok if you remove your air filter housing stand in front of the car on the air filter side look down behind the bulkhead and you will see it at the bottom make sure you don't brake the clip when taking it off and make sure you take the old o ring out too just get a new clip and o ring when you buy the temp sensor one tip is you could tie a string to the clip incase you drop it at the back of the engine removing the clip is the only tricky thing
  3. Re: Coolant Temp Sensor
    May 2011
    Nairn, Scotland
    My temp gauge usually sits about 75ish goes up to high 80s then drops back again. Plenty hot air from the heater altho the gauge drops back to under 70 when the heater is switched on.
    The radiator fan appears to spin all the time, is this normal?
    Only getting low 40's mpg and suspect the extra cooling is causing this.
    Thermostat, temp sensor, fan fault or combination of them?
  4. Re: Coolant Temp Sensor
    Mar 2011
    Croydon UK
    Not sure - After I noticed my gauge fluctuating I plugged VCDS lite into mine & it shows a fault for the Coolant Temp Sensor.
    Audi A4 B6 TDI 130
  5. Re: Coolant Temp Sensor
    Jan 2009
    Birmingham
    36 Post(s)
    Most Likley a coolant temp sensor try changing it if it does not do the trick thermostat lazy and cooling engine that needs changing but first try coolant temp sensor easy and cheap
  6. Re: Coolant Temp Sensor
    May 2011
    Nairn, Scotland
    Does faulty temp sensor also effect mpg?
    A6 2.7tdi S-line Le Mans saloon
    A4 tdi 115 Estate 54 plate
    Oct 2010
    Here And There
    I would try a stat indeed.
  8. Re: Coolant Temp Sensor
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Is the plug in device on the bottom of the radiator the sensor/sender to the gauge/fans, as opposed to the items on the engine plumbing which send to the ecu
    A6 2.4 SE (2000)S3 1.8T (2001)80 Coupe 2.3 (1991)
    A3 1.8T sport (1997)A4 3.0 QST (2002)
    80 Coupe 2.6S (1995)A4 Cab 2.4 sport (2002) Another 2.6 '95 coupe in byzanz purple
    '88 type 89 90 saloon kv 5 pot A4 1.8T 2001
  9. Re: Coolant Temp Sensor
    May 2011
    Nairn, Scotland
    When I was doing this job I checked to see if there was water under the battery, there was so I reached in under the battery and removed a rubber 'plug' which is about 2 inches long and an inch wide. A lot of water gushed out, is this going to solve the problem or do I need to do something else. Is it ok to leave this plug out?
  10. Re: Coolant Temp Sensor
    May 2011
    Nairn, Scotland
    Just had thermostat changed and it's made no difference, the old thermostat was checked and was operating properly.
    The guy said the water is not circulating round the engine, I had a new cambelt and waterpump fitted about 2 weeks ago. A dodgy pump by the sounds of it or something else? Help!!!!
  1. coolant temp sensor
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2010, 09:26 PM
  2. coolant temp sensor.
    By zollaf in forum Fabia
    Last Post: 06-05-2009, 12:06 PM
  3. How To coolant temp sensor
    By Jake1979 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-04-2009, 08:38 PM
  4. Coolant Temp Sensor & Temp Gauge
    By amz in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2009, 10:19 AM
  5. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
