Thread: Coolant Temp Sensor
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
  1. Coolant Temp Sensor
    Mar 2011
    Croydon UK
    Hi Guys, My Coolant Temp sensor is intermitant ( fluctuates between 50 & 90 when car has been running for a while) , can someone tell me where this is located in the engine bay? hopefully will be able to get a new one & fit it at the weekend.
    Audi A4 B6 TDI 130
  2. Re: Coolant Temp Sensor
    Jan 2009
    Birmingham
    36 Post(s)
    Ok if you remove your air filter housing stand in front of the car on the air filter side look down behind the bulkhead and you will see it at the bottom make sure you don't brake the clip when taking it off and make sure you take the old o ring out too just get a new clip and o ring when you buy the temp sensor one tip is you could tie a string to the clip incase you drop it at the back of the engine removing the clip is the only tricky thing
  3. Re: Coolant Temp Sensor
    May 2011
    Nairn, Scotland
    My temp gauge usually sits about 75ish goes up to high 80s then drops back again. Plenty hot air from the heater altho the gauge drops back to under 70 when the heater is switched on.
    The radiator fan appears to spin all the time, is this normal?
    Only getting low 40's mpg and suspect the extra cooling is causing this.
    Thermostat, temp sensor, fan fault or combination of them?
  4. Re: Coolant Temp Sensor
    Mar 2011
    Croydon UK
    Not sure - After I noticed my gauge fluctuating I plugged VCDS lite into mine & it shows a fault for the Coolant Temp Sensor.
    Audi A4 B6 TDI 130
  5. Re: Coolant Temp Sensor
    Jan 2009
    Birmingham
    36 Post(s)
    Most Likley a coolant temp sensor try changing it if it does not do the trick thermostat lazy and cooling engine that needs changing but first try coolant temp sensor easy and cheap
  6. Re: Coolant Temp Sensor
    May 2011
    Nairn, Scotland
    Does faulty temp sensor also effect mpg?
    A6 2.7tdi S-line Le Mans saloon
    A4 tdi 115 Estate 54 plate
  7. Re: Coolant Temp Sensor
    warp_speed Guest
    Yes, because the car will change the amount of fuel used in the cylinders because it thinks the engine is cold and will add more fuel to the mixture to improve cold start. Your idling might be affected as well because the mixture is too rich. Had a friend who's 1.8 Golf GTI ran like a bag of spanners, a quick scan came up with the coolant sensor being duff. New sensor and all is well.
  8. Re: Coolant Temp Sensor
    May 2011
    Nairn, Scotland
    cool, I'm seeing sensors on ebay for around £8 with new clip and 'o'ring. Does that sound correct? or best going to Audi for genuine part?
  9. Re: Coolant Temp Sensor
    Southern County Softy
    20 Post(s)
    Get a genuine part
    A4 2.5 tdi QS (mapped)
  10. Re: Coolant Temp Sensor
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Genuine
  1. coolant temp sensor
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2010, 09:26 PM
  2. coolant temp sensor.
    By zollaf in forum Fabia
    Last Post: 06-05-2009, 12:06 PM
  3. How To coolant temp sensor
    By Jake1979 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-04-2009, 08:38 PM
  4. Coolant Temp Sensor & Temp Gauge
    By amz in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2009, 10:19 AM
  5. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
