Thread: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
  1. 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    Jun 2009
    Isle Of Wight
    OK so I have a 2001 1.8T Q AVJ Engine. I keep getting this error code, clear it and it comes back again. I have no performance issues, no warning lights just this damn code every time I run a check with VCDS Lite. I have looked at the Ross Tech site and can happily say its not an oil pump issue as it's all squeaky clean.
    So the question is, should I replace the sensors ?
  2. Re: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    Mar 2011
    Kendal Cumbria UK
    I would assume only one is going as its the correlation between the two thats throwing up the code, but your guess is as good as mine as to which! Maybe get test procedures for the 2 and see if resistances are off on one?
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  3. Re: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    Jun 2009
    Isle Of Wight
    I think I have answered my own question, the parts are a little expensive to play swap out. With no issues me thinks I shall just leave it for now
  4. Re: 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
    131 Post(s)
    1973 Post(s)
    On a 1.8T engine this can be an early warning of oil pressure problems (blocked oil pump pick up) and wear in the cam relay chain adjuster which drives the inlet cam from which the G40 is signalled. If the problem progresses the inlet cam can jump on the chain and cause valve to piston contact.
  1. How To G28 Engine Speed Sensor
    By Silver in forum Polo - Derby - Lupo - Fox
    Last Post: 25-09-2016, 03:34 PM
  2. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
  3. Please Help Camshaft Position / Hall Sensor 17746 - (G40): Open or Short to Plus
    By thor_wulff in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-12-2008, 12:51 AM
  4. Camshaft Sensor (G40) - where is it?
    By Mat456 in forum Golf MK3 - 1993 - 1999
    Last Post: 25-12-2007, 11:00 AM
  5. G28 Engine Sensor
    By cb95amc in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-09-2006, 01:43 PM
