Thread: Gearbox Solenoid Replacement
  1. Gearbox Solenoid Replacement
    Dec 2008
    Hi All,
    Could anybody tell me how much it would be to replace a solenoid in my gearbox? I have a 2004 A4 Multi-tronic Cabriolet displaying the following fault codes:-
    CODE001: 17137 P0753 Shift Solenoid A-N88: electrical - Output dose not have a contact short to earth
    CODE002: 17134 P0750 Shift Solenoid A-N88: malfunction - Value of resistance too great.
    Any help appreciated.
    G
  2. Re: Gearbox Solenoid Replacement
    Apr 2011
    oxford
    hello GJC , did you have any luck replacing your solenoid ?
    i had gearbox fault codes and flashing lights etc , range sensor faulty so I took the ecu out to get it checked at BBA reman , they said there was damage to the ecu and repaired it so i have re fitted it and refilled the oil .
    Maybe I havent done the oil fill correctly or maybe there is too much oil in it but now the car takes ages to take off and when it does it tend to give you whip lash , there is occasional judder but not really bad .
    I guy at work plugged in and now it is showing faulty solenoid or intermittent fault / signal so perhaps I am going to be in the same situation as yourself very soon.
    I will let you know if I find anything
  1. Please Help gearbox replacement
    By taxi3528 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 06-04-2010, 12:57 AM
  2. A8 gearbox replacement
    By dirtworks2000 in forum A8 - S8 - V8
    Last Post: 03-09-2009, 09:01 PM
  3. Please Help Gearbox Solenoid
    By doubledeclutch in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-05-2009, 02:02 PM
  4. Please Help Replacement Gearbox!
    By p1234b in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2008, 10:27 PM
  5. Gearbox replacement
    By rained_mob in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2008, 10:44 AM
