Thread: Passat B6 tFSI 2006 Est
Results 1 to 10 of 14
  1. Passat B6 tFSI 2006 Est
    Sep 2008
    SE London
    As it's coming up to 39k now, there's just a few things I'm curious about:
    Up to now have been using main agent for warranty reasons for periodic service on the two year cycle: They say that they use the same engine oil for both but unless you watchit your service book will only be signed up for one year's and tbe service history not up rated to +20k miles
    Now ready for 40k, service reminder came on at 38,800 as expected (corrected) via VCDS. About a week later the "check brake pads" warning came up. Had a set of new rears but the fitter said originals were only half worn. But given the mileage had them changed anyways. How does the Management Control Unit know when they're worn and needing replacement? There isn't any leads coming out of the pads to be able to give that info. But I'm well out of date as last time I did my own maintenance was in mid-80s on Rover P6 and P5...
    Havn't had the fronts done yet but the fitter says they're about the same wear. Had new ones fitted to fronts when I bought the car as part of the deal, so they're 9,300 miles less worn
    The pads' warning light is still on: here's the VAG (10.6.4) printout section prior to changing the rear pads
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 095 Q HW: 3C0 614 095 Q
    Component: ESP 440 C2 H015 0003
    Revision: H015 Serial number: 0667233697
    Coding: 0013731
    Shop #: WSC 05311 000 00000
    VCID: 3041DD31DAB3
    2 Faults Found:
    01423 - Lateral Acceleration Sensor (G200)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 131
    Mileage: 62431 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:16
    01542 - Yaw Rate Sensor (G202)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 131
    Mileage: 62431 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:16
    I see from the EOBD utiliity (Martin pls e-mail me for all my logs, don't have your addy and have only posted seven times before)
    that this G200/G202 will show when there's a warning light on, which there is (check pads) along with the "Service Now" warning which I havn't yet reset
    More info gratefully received. It's probably in a FAQ somewhere on this site but as yet havn't found it. Should I be doing a VCDS reset somewheres to turn off this warning in addition to cancelling DTCs?
    Not worried about springing for the front pads too, but will be if it doesn't turn off the pads' warning!
    Cheers RichardSEL
  2. Re: Passat B6 tFSI 2006 Est
    Norfolk
    Brake pad warning is not via control units so VCDS doesn't reset it. Rear pads do not have a pad wear warning, only front ones. So if warning light is on, the front pads are worn.
    Pad wear warning light will only go out when new pads are fitted. Two year service is 30,000 km which is 18,750 miles not 20,000 miles.
  3. Re: Passat B6 tFSI 2006 Est
    Sep 2008
    SE London
    Quick post to thank you for your quick reply
    Only front pads monitored... hmmm Thats an advance from my 70s and 80s so-called "old crocks"((c) her indoors)
    And shows, with moderate use, fronts last less than 30k...
    RichardSEL
  4. Re: Passat B6 tFSI 2006 Est
    Sep 2008
    SE London
    Just an update:
    Did the front pads and warning light off.
    Only the nearside front pad is monitored for wear by means of flying lead. It was that pad that showed the most wear. Double Hmmm...
    This just leaves this odd one showing in Vag:
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 H HW: 3C0 937 049 H
    Component: Bordnetz-SG H37 1301
    Revision: 00H37000 Serial number: 00000005320486
    Coding: E48C8F0700041A00000A00000F000000000859435C0000
    VCID: 2E7DC349C087
    Part No: 3C2 955 119
    Component: Wischer VW461 012 0503
    Coding: 00063445
    Shop #: WSC 05311
    Part No: 1K0 955 559 T
    Component: RegenLichtSens 011 1110
    Coding: 00208933
    Shop #: WSC 05311
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 62431 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 8.55 V
    OFF
    OFF
    OFF
    OFF
    OFF
    and
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Component: Tuer-SG 024 2366
    Coding: 0000756
    VCID: 3753E62D3FDD
    1 Fault Found:
    00933 - Electric Window Motor; Passenger Side (V148)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Just going to check again after standing overnight...
    Yep, still the same. Codes 00446 and 00933 not shown in EOBD database
    I would check fuses but since the layouts are wrong or documented as with a reversed diagram, that's not much help telling where to start. All the window motors work from both their controls as does the locking
    Any ideas anyone?
    RichardSEL
  5. Re: Passat B6 tFSI 2006 Est
    Norfolk
    You seem to misunderstand how VCDS & coding works. "Yep, still the same. Codes 00446 and 00933 not shown in EOBD database"
    VCDS gives the VAG 5 digit coding, eg. 00933 and tells you what the code means, 00933 - Electric Window Motor; Passenger Side (V148).
    It even gives you a sub code, eg. 005 - No or Incorrect Basic Setting / Adaptation - Intermittent.
    You won't find specific VAG codes in an EOBD list. The EOBD codes are only those that all European manufacturers have agreed to use. They are generic for all european vehicles and are not a good guide for diagnostics.
    Your two codes are often triggered by someone disconnecting the battery, having a flat battery or jump starting a car.
    To try to clear them. Disconnect the battery for a few minutes. Reconnect. Fully open and close each electric window to establish wide open/fully closed. Drive car. Rescan.
    This should clear the codes. It may not. Sometimes these silly codes get stuck, in which case you just ignore them.
  6. Re: Passat B6 tFSI 2006 Est
    Sep 2008
    SE London
    Even more helpful stuff from Martin...
    Did as suggested and found following after about 10 mins disconnect of battery, re-connect, then a drive around for 10
    Now can't see auto trans although status is still given as "OK"
    Address 02: Auto Trans Labels: 09G-927-750.lbl
    Part No SW: 09G 927 750 T HW: 09G 927 750 T
    Component: AQ 250 6F 0832
    Revision: 00H38000 Serial number:
    Coding: 0000072
    VCID: 42A587F9641F
    No fault code found.
    But now get:
    Cannot be reached
    However back to the previous, still getting:
    VCID: 2E7DC349C087
    Coding: 00063445
    Shop #: WSC 05311
    Coding: 00208933
    Shop #: WSC 05311
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 62431 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 8.55 V
    OFF
    OFF
    OFF
    OFF
    OFF
    and:
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Coding: 0000757
    VCID: 364DEB2938D7
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    with:
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Part No SW: 3C0 959 433 K HW: 3C0 959 433 K
    Component: KSG PQ46 ELV 038 0455
    Revision: 00038000 Serial number: VWZCZ000000000
    Coding: 0191020851030E763804941570085FCE103980
    VCID: 3245D739D4BF
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 3C0 951 171 A
    Component: Neigungssensor 002 0508
    Component: Innenraumueberw.002 0508
    1 Fault Found:
    00323 - Vehicle Inclination Sensor (G384)
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 62677 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:03:25
    and:
    Coding: 0000756
    VCID: 3753E62D3FDD
    1 Fault Found:
    This is getting interesting!
    RichardSEL
  7. Re: Passat B6 tFSI 2006 Est
    Norfolk
    Did you do the open and close windows trick. That should have sorted the window fault. Try again just using the driver door switches. Make sure windows hit the full open, wait a few seconds and then close. Do this a couple of times. Is it possible something is stopping the window closing fully, because that will upset it. What VCDS are you using because you shouldn't be losing communication.
    Just a thought. Have you had any work done recently that might have disturbed any wiring ?
  8. Re: Passat B6 tFSI 2006 Est
    Sep 2008
    SE London
    For ignition only first thing this morning:
    Coding: 0000072
    VCID: 42A587F9641F
    VCID: 2E7DC349C087
    Coding: 00063445
    Shop #: WSC 05311
    Coding: 00208933
    Shop #: WSC 05311
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 131
    Mileage: 62431 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 8.55 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Coding: 0000757
    VCID: 364DEB2938D7
    1 Fault Found:
    VCID: 3245D739D4BF
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 62677 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:03:25
    Coding: 0000756
    VCID: 3753E62D3FDD
    1 Fault Found:
    And after startup, idle in park:
    Cannot be reached
    0446 is the same
    Address 42 the same
    Address 09 the same
    Address 42: Door elec, driver the same
    Address 46 the same
    Address 56 the same
    Both autoscans were done after twice cycling each window up and down using their own door mounted toggle switch
    VCDS is ver10.6.4 CAN only gateway
    Some years back had the rear windows' tints done but can't find any docs about this so don't know the exact date (two years' ago?)
    But the rear windows' motors arn't showing any faults
    Looking back thru all saved logs, under VCDS ver 908 the Autotrans does show "can't be reached" after a 2nd attempt on 15th Oct 2009. Then:
    Address 46: Central Conv. Labels: 3C0-959-433-46.lbl
    1 Fault Found:
    00896 - Trunk Lock Unit (F256)
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 36094 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:52:5
    I didn't follow this up as was more concerned with the engine flap motor issue. Main dealer did the flash update under warranty (but didn't do the basic setting afterward <sigh>)
    It wasn't until 17th August last year that the "Lower Voltage limit exceeded" messages started appearing
    RichardSEL
  9. Re: Passat B6 tFSI 2006 Est
    Dec 2010
    manchester
    Hi Richard,
    where did you find the right brake pad for your car??
    according to vcds, the part number is 3C0 614 095 M
    i need to change my front ones
    please help, thanks
    Part No SW: 3C0 614 095 M HW: 3C0 614 095 M
    Component: ESP 440 C2 H015 0001
    Revision: H015 Serial number: 0657961014
    Coding: 0013569
    Shop #: WSC 00028 028 00001
    VCID: 2C5C06EEB051217C
  10. Re: Passat B6 tFSI 2006 Est
    Norfolk
    3C0 614 095 M is the cintroller, not the pads. You can't get part numbers using vcds.
    Front pads are 5K0 698 151 followed by a letter. Cost about £75 from VW and half that from a factor like eurocarparts or GSF
  1. Timing belt on 2006 A4 TFSI Quattro
    By icun in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 15-03-2010, 09:12 PM
  2. Question Passat est R NSWindow
    By Trev Lees in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 27-08-2009, 01:31 PM
  3. Please Help Passat Est Steamy Windows
    By dom2005w in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-03-2009, 07:23 PM
  4. breaking passat est bits anyone ???
    By golf tdi 02 in forum Early Passat Forum - Pre 97
    Last Post: 13-05-2008, 09:58 AM
  5. 07/04 Passat Est. - EU Light Adjustment
    By pontyslapper in forum Passat - Archive Topics
    Last Post: 28-12-2007, 05:55 PM
