Thread: Fault With Lights
  1. Fault With Lights
    Dec 2007
    Bedford
    Evening guys I have a wierd issue with my lights.
    This evening I started my car to go to work and the indicator lights would not work. I put on my hazord lights and they started to flash fine so I turned them off tested the indicators and they worked fine again.
    I have left the car in the car park the indicators now keep flashing when the car is locked (the alarm is not going off). When I push the hazard light button to switch them off the headlights on the car come on and all the internal lights (like the dash light) go off for a second and then the hazards stop flashing.
    This is ok for a minute or two however then just keeps happening again.
    Any quick fixes I could try tonight?
    The only recent work I have had done is to install LED sidelights with resistors... Not sure if this is linked as they have been working fine.
    2017 Audi A5 (B9) Coupe 2.0 TDI S-Line Quattro S Tronic
  2. Re: Fault With Lights
    Mar 2011
    Kendal Cumbria UK
    Sounds like it may be a dodgy hazzard/indicator relay (which is the hazzard switch as its all one unit).
    But im not 100%.
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  3. Re: Fault With Lights
    Dec 2007
    Bedford
    I've done a bit of searching and it seems to be a common fault on Audi & VW cars.
    I also found this old post: https://www.vwaudiforum.co.uk/forum/s...ndicator-fault
    I did get the car washed this morning and did find a bit of water in the driver footwell (never ever happened before).
    I have also just checked everything and the internal lights in the car dont come on when you open the doors but do come on when you press the on button.
    Also when turning the hazzard light off all the interal lights including the dash go out for a seccond.
    Also my boot will not open and lastly the electric windows have all stopped working... I have checked the fuses and they seem to be fine.
    I have read other pages where it might be a fault with the "Comfort Pack" in the car as I know the above problems are all on the same fuse... I have tried taking out the indicator fuse which stops the indicator stalk from working but the hazzords will still blink!
    I have resulted in disconnecting the battery until I finish work... Will take it to an Audi specalist in the morning and hopefully they will be able to investigate it first thing.
  1. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    By rogerholmesuk in forum Golf MK5 - 2004 - 2009
    Last Post: 11-05-2011, 09:03 PM
  2. HELP!! steering,ABS and Airbag fault lights on my dash
    By BROWN_OWL in forum Golf MK5 - 2004 - 2009
    Last Post: 29-01-2009, 08:59 PM
  3. 2002 Polo - Lights On Warning Buzzer Fault
    By ozzvw in forum Polo - Derby - Lupo - Fox
    Last Post: 15-10-2008, 01:05 PM
  4. 00 Passat- brake fault, abs, traction control lights on
    By rallen043 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-09-2007, 10:53 PM
  5. More S3 Fault lights
    By AK30 in forum Audi A3 - Archive Topics
    Last Post: 30-05-2007, 06:46 PM
