Thread: What is it called
  1. Question What is it called
    TomClarke Guest
    Part for a 2002 Audi A4 Avant 1.9tdi
    After dropping off a parcel at my bosses house I went through his automatic gates and the plastic housing underneath the engine was ripped off by a high piece of metal on the floor. I have removed the broken plastics but cannot think of what it is called, I want to buy the part and fit it myself, could someone tell me what the part is called or the number for the part.
    Any suggestions for the part name will be appreciated
    Tom
    Oct 2005
    It's known as any one of the following;
    Belly pan
    Skid plate
    Under-engine cover
    Skid pan
    etc
    www.vagcat.com will help with part numbers. Let me know if you need a hand or can't work it and I'll try but I don't have time at the moment.
    TomClarke Guest
    Hi Sam
    I had a quick look but I couldnt find the part
    Tom
    Oct 2005
    Right, I think I've found it!
    Audi A4/Avant, 2002 г.в.
    Go into Body and it's under the section called SOUND DEADENER / COVER FOR JOINTED SHAFT / COVER FOR ENGINE COMPARTMENT
    Coventry
    I think i've found the answer you seek.
    Can't post it tho. PM sent
    let me know if its of any help.
    Coventry
    spooky
    this it the same as the image i sent via pm but from a publicly available source
    Oct 2005
    Quote Originally Posted by GOLFMK5GTTDI View Post
    I don't understand why you can't post it here?
    spooky
    Now I'm even more confused, you say it's the same image BUT from a publicly available source. Mine was from a publicly available source - www.vagcat.com as detailed above.
  1. What is this called?
    By radneo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-06-2007, 10:00 PM
  2. Replies: 0
    Last Post: 20-07-2006, 09:04 PM
