Thread: Help?? 1990 Audi 90 2.3E NG Loosing power on W.O.T???
  1. Help?? 1990 Audi 90 2.3E NG Loosing power on W.O.T???
    Apr 2011
    Newry, Northern Ireland
    Hi all,
    i have a 1990 audi 90 2.3E (NG Engine)
    The car seems to die off when i put my foot to the floor,
    Not so good when it cant be floored to overtake!
    Any one any ideas?
    Tia
  2. Re: Help?? 1990 Audi 90 2.3E NG Loosing power on W.O.T???
    Gwent
    fuel filter ok? Air filter?
    Are you certain this is a throttle position problem? eg if you have a 4 cyl car's fuel pump relay fitted, the rev limiter will be set too low.
    There could be a throttle position switch problem? I think the NG just has an Idle switch and a wide open throttle switch. Not sure what the problem would be, but hitting the w.o.t. switch would seem to be having the wrong effect. Usually hitting w.o.t., the ecu gets a signal and no longer controls fuel mixture according to lambda sensor readings, instead fuelling is done by the metering head.
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  3. Re: Help?? 1990 Audi 90 2.3E NG Loosing power on W.O.T???
    Apr 2011
    Hi scotty33,
    Yeah fuel filter been changed, Brend new K&N panal filter installed last weekend.
    the car is fine right up to W.O.T
    The car has only a genuine 52000 miles on it, was a disabled guys car, and all but the last 2 servces where done by audi.
    So this is frustrating me somewhat lol
    how would i know if it had the wrong fuel pump relay?
    TIA
    Dan
  4. Re: Help?? 1990 Audi 90 2.3E NG Loosing power on W.O.T???
    Gwent
    The rev limiter operates at 4 fifths of where it should be, when a 4 cyl relay is used in a 5 cyl car. So rev limit would be approx 5000 rpm instead of 6500ish?
  5. Re: Help?? 1990 Audi 90 2.3E NG Loosing power on W.O.T???
    Apr 2011
    No its not that then, revs well above 6000, that would have been an easy fix!
  6. Re: Help?? 1990 Audi 90 2.3E NG Loosing power on W.O.T???
    Gwent
    I think you need to test the operation of the idle and wot switches, it could be the case that at wot the signal is being seen at the ECU as the IDLE switch being made, not the wot. If this is the case it thinks you are on the overrun and shuts the fuel off. I don't know if this is a switch problem or maybe a wiring short? I can't think of anything else to suggest..
  1. Please Help 1.2 Polo Loosing Power
    By NeilMorey in forum Polo - Derby - Lupo - Fox
    Last Post: 24-01-2010, 12:29 PM
  2. t4 loosing power
    By Ricky Young in forum The Commercial Range
    Last Post: 28-09-2009, 06:42 PM
  3. Question AUDI A4 B6 2002 2.0 CVT Loosing acceleration power when engine gets hot. Please help?
    By dg102 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2009, 02:58 PM
  4. Please Help LT 35 Loosing power and cutting out
    By mksound in forum The Commercial Range
    Last Post: 30-08-2008, 03:51 PM
  5. audi 100 1990 power steering problem
    By tonos in forum 100 - 200 - Turbo - 100 S4
    Last Post: 08-01-2007, 11:27 AM
