Thread: Replace Reversing Light on Sharan
  1. Lightbulb Replace Reversing Light on Sharan
    Feb 2006
    Having damaged the reversing light on my 2004 VW Sharan. (I reversed into a tree). This means replacing the whole light unit.
    Does anyone know how to remove the boot door interior panel to gain access to the light unit?
    Any advice about how to replace the light unit?
    Thanks very much for any help.
    Neil.
    Feb 2006
    OK, I have now done the job. Here's how to replace the Reversing Light Unit or the Fog Light Unit:
    The Reversing Light Unit and the Fog Light Unit are contained in the boot lid of the VW Sharan. To get at these units you have to take out the boot/door panel by removing two screws located within the light access panels. Also unscrew the grab handle. The panel now pulls off.
    You then have to unscrew 11 nuts within the door, remove the registration plate and the two reg plate lights. The entire external plastic panel can then be removed. Each Light Unit can then be removed from this panel by unscrewing two bolts per unit.
    The hardest part of the re-assembly is replacing the boot/door panel. You need two extra people to guide the panel into place and push the panel into it's clips.
    Someone, somewhere might find this useful I guess.
    Neil.
  1. Reversing lights not working.
    By Mack57 in forum Touran - Sharan - Caravelle
    Last Post: 01-09-2013, 11:42 AM
  2. A3 reversing lights
    By Graham in forum Audi A3 - Archive Topics
    Last Post: 11-09-2007, 12:07 PM
  3. Replacing reversing light switch - Passat.
    By jakefouro in forum Archive posts
    Last Post: 03-02-2007, 01:58 PM
  4. sharan and abs light!!!
    By madmum in forum Touran - Sharan - Caravelle
    Last Post: 24-11-2006, 08:28 AM
  5. mk 4 1.8t reversing light switch
    By cbrrocket6 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-11-2006, 12:47 AM
