Thread: tow bar electrics
  1. tow bar electrics
    Oct 2009
    oldham
    thinking of buying a s/h towbar and doing single electrics. It looks as if you need a byepass relay. Has anyone experience of doing the wiring. thanks mick
  2. Re: tow bar electrics
    Kinross Scotland
    Yes you need the bypass relay, and there is a very good "howto" on this forum here :- https://www.vwaudiforum.co.uk/forum/s...-towbar-thread with thanks to Ben.
    One point different to what is on the thread is the location of the reverse light pickup point which is in the wiring harness over the rear nearside wheal arch. Wire colour is black/blue and the it changes to white at a juction near the wheel arch to get at it you need to remove the rear seat, the wheel arch trim and the trim that the parcel shelf rests on. It is all easy and only takes a few minutes just look for the blanking plate for the hidden screw near the rear seat belt cassete spooler dont force anything as when you have the neccessary screws out it is only clips which you can break if you are brutal.
    Most people pick up the +12v for the relay power supply by clipping into the power socket supply in the boot, but I recently used this for tapping a power supply and it is very tidy and proffesional (use fuse 42 in the side dash fuse box, it is the cigi lighter socket)
    http://cgi.ebay.co.uk/ADD-A-CIRCUIT-...item53e61878f0
    Tiguan 2.0 4Motion 140PS 01/07/2013
  3. Re: tow bar electrics
    Oct 2009
    oldham
    Quote Originally Posted by richard@thebrae View Post
    hi
    thanks for that info, its very helpfull. mick
  1. Tow bar electrics 7 way bypass relay
    By davidcatton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-05-2011, 06:51 PM
  2. what happens if i dont activate tow bar electrics?
    By allroadkev in forum VCDS - General Questions
    Last Post: 08-05-2010, 11:05 AM
  3. Tow bar electrics
    By m12oby in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-02-2010, 01:30 PM
  4. new tow bar/dodgy electrics
    By hazhammy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-08-2009, 10:38 PM
  5. sharan tow bar electrics
    By deano224 in forum Touran - Sharan - Caravelle
    Last Post: 13-08-2009, 01:01 AM
