Thread: FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
  1. FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    Nov 2010
    Bristol
    Hi. I fitted a xcarlink usb module today. Went fine. I unhooked the battery to do it. Put the battery back on and i have two fault lights come up. The car hasn't been anywherw!!! The ESP on light is on at the switch above the gear stick and the Electro Mech Steering light is yellow in the dash. I haven't taken the xcarlink back out again, as its a pain to fit. And i'm assuming that fault lights don't just go away of their own accord.
    Does anyone know how to fix this, without a costly trip to a dealer. Any help with this would be much appreciated. Is there anyone in Bristol area who can look at it with the VAG COM computer.Thank you.
    MK5 GOLF GT140 Tdi 2006 Facelift.
  2. Re: FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    Up North
    You sometimes get wierd fault lights up if the battery goes flat or is left disconnected for an extended period. Electric windows and folding mirrors get confused too. Try driving it around the block, making sure you include having the steering on full lock in both directions a couple of times. Nine time out of ten it will clear the fault lights. If you find the windows and mirrors are behaving oddly, just cycle them up and down or in and out several times.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  3. Re: FAULT LIGHTS up after fitting Xcarlink. ESP ON, Elec Steering fault light on
    Nov 2010
    Bristol
    Quote Originally Posted by Teflon View Post
    Thanks for this . YOU ARE 100% right. I re hooked the battery and did the drive...it didn't clear for 50 meters or so, then..magic they went out like xmas lights. THANK YOU again.
  1. Question Audi A3 ESP fault light
    By tiptopjohn in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-02-2011, 08:33 PM
  2. Please Help ** ESP FAULT ** light has come on twice now.... HELP....!!!
    By pezlaa in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-12-2010, 03:18 PM
  3. ESP fault light on
    By huby6684 in forum Golf MK5 - 2004 - 2009
    Last Post: 10-07-2010, 08:56 PM
  4. HID Xenon ESP ABS Handbreak fault lights come on
    By thomswalwell in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2010, 07:35 PM
  5. Question ESP Fault light
    By Audiman1971 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-07-2009, 12:16 PM
