Thread: DSG Losing Drive
  1. DSG Losing Drive
    Solihull
    I had a strange experience today. I was driving home from work and as I turned into my road - about 15-20MPH - I tried to accelerate, but the engine revs just went straight up and I didn't seem to have any drive, like clutch slip or not in gear. The dash display said I was in 3rd gear. I lifted off the gas and tried again and it seemed to be OK again.
    I then only drove another 400 yards to my house, without issue.
    Has anyone else experienced anything like this?
  2. Re: DSG Losing Drive
    DSG4ME Guest
    Quote Originally Posted by daveo138 View Post
    Get it serviced if it's over 40k, you should get updated FW as well, mine does this when quick changing from reverse to forward.
  3. Re: DSG Losing Drive
    Solihull
    I was just wondering if there is another known DSG issue.
    I already had three replacement mechatronic units, then a new gearbox at 56k. It's now done 107k.
  4. Re: DSG Losing Drive
    DSG4ME Guest
    What is the service history of the box Dave, how many oil changes has it had since the last box was fitted?
  5. Re: DSG Losing Drive
    Solihull
    It hasn't had an oil change since replacement.
  6. Re: DSG Losing Drive
    DSG4ME Guest
    Can't say for sure if it is that, but you are 11k over the recommended so it's feasable the filter is dirty and restricting the flow, if you want a "cheap" try you could go get a new filter and some DSG oil (enough for a filter soak) and do just that, put the new filter in a bowl of oil and let it fully soak in, then just replace the filter, that way you get a like for like capacity without spending the £180 for a full oil and filter change, personally I think it's the filter more than the oil that demands the DSG service.
  1. Please Help A6 multitronic issue gearbox ecu knew from audi still juddering and losing drive.
    By jacobkleber in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2011, 02:18 PM
  2. Replies: 1
    Last Post: 10-05-2011, 10:12 PM
  3. DSG No Drive
    By asm51 in forum Golf MK6 - 2009 - 2013
    Last Post: 20-10-2010, 06:26 PM
  4. DSG Brakes On To Engage Drive
    Last Post: 14-04-2010, 10:10 AM
  5. passat 2007 tdi dsg no drive??
    By toma69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2010, 06:46 PM
