Thread: A6 4F MMI 2g control head settings
  1. Question A6 4F MMI 2g control head settings
    Mar 2009
    Helsingborg, Sweden
    Hi all
    Can anyone give me some initial settings for the 07 Front Control Head, I have done the 5570 update and it seems some channel settings have changed. Eg, channel 19 has gone from 65535 to 51 !!!!
    So if some can help it would be appreciated
  2. Re: A6 4F MMI 2g control head settings
    May 2007
    knee deep in clunge
    14 Post(s)
  3. Re: A6 4F MMI 2g control head settings
    Mar 2009
    Helsingborg, Sweden
    Thanks A8 but I don't see any value for channel 19, having just checked my notes I can see that it had the same value as channel 18 -65535 but now 19 is only 3. Have just tried to change it to 65535 but it won't let me.
    I've also enabled the hidden menu but the Battery Indicator and Oil Level do not appear anywhere.
  4. Re: A6 4F MMI 2g control head settings
    May 2007
    knee deep in clunge
    14 Post(s)
    ignore channel 19 it has no impact
    you must re initiate battery display etc via adaptation channels in address 07 and not by hidden menu
    so goto address 07 channel 2 delete the value stored and add value 32 and save
    now goto channel 111 and set to 1 and the mmi reboots
    battery display will now appear
    now you can work your way through the functions via adaptation to re install your user settings and remember to use channel 111 to reboot and apply changes
  5. Re: A6 4F MMI 2g control head settings
    Mar 2009
    Helsingborg, Sweden
    Thanks A8 tech. It's my first job when I get home tomorrow. It's really quite interesting but also a bit scary in case things go wrong. Luckily for the forum members we have someone like you that we can turn to, and I for one are very grateful.
  1. MMI control replacment
    By ahelbawi in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 07-03-2010, 07:46 AM
  2. 2001 A3 cylinder head bolt torque settings
    By arcangels in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-12-2009, 12:38 AM
  3. MMI Settings
    By Adrian Williams in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-10-2009, 08:53 PM
  4. MMI Control Button
    By Samurai1466 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-05-2008, 09:45 AM
  5. MMI Control
    By grantza in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 19-09-2007, 10:01 PM
