Thread: knocking noise coming from front wheel
Results 1 to 9 of 9
  1. knocking noise coming from front wheel
    May 2011
    Ireland
    Hi lads, i got a new cv joint fitted to my 04 audi a4 tdi about 2 months ago and recently i have started to hear a clicking or slight knocking noise in that area again when turning left or right....it does not happen until i drive a few miles then i hear it, i had a local mechanic look at it and he said no grease was leaking from the boot and it seemed fine but does any1 no what it could be??? Thanks
  2. Re: knocking noise coming from front wheel
    Apr 2009
    A CV knocking is a quite distinctive loud metallic click, which can be induced by applying the power,
    in 1st gear, while on full lock. The timing of the knock increases with the speed of the wheel revolution.
    Any other type of knocking could be related to suspension arms, ARB or even brake pads/calipers.
    Regards
    Jim
  3. Re: knocking noise coming from front wheel
    Dec 2010
    Chester
    Does the clicking increase with wheel speed and can you feel it anywhere (steering, pedals etc) or just hear it?
    A4 AVANT 2.5tdi SPORT QUATTRO
  4. Re: knocking noise coming from front wheel
    May 2011
    Ireland
    yea the clicking does increase with speed but no i dont feel it anywhere in pedals or steering i just hear it, mainly just turning left very seldom when going right....any idea what it could be man??
  5. Re: knocking noise coming from front wheel
    Ireland
    Quote Originally Posted by AlanMcC1 View Post
    it sounds like it could be gone again. Was it an OEM part installed and are you sure there was grease in there in the first place?
    Which joint did you get done before (left/right)?
    Left joint will sound more pronounced when locking right in first gear as Jim says and visa versa
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  6. Re: knocking noise coming from front wheel
    May 2011
    Ireland
    ah god i didnt tink it would go again no it wasnt an OEM part i got it from a car parts shop but do im going to go back in and ask them have i got a guarentee on the part as i only bought it on 8/2/2011.
    I got the right one done and this is the one thats giving me trouble again. mechanic said it was finr and no leaking grease so i dont know what it could be
  7. Re: knocking noise coming from front wheel
    Ireland
    Is it the same mechanic that installed it inspecting it now? If so what does he think it is?
    Why dont you pull the boot back and check for grease. If its really knackered you might even feel some play there.
    I suspect the parts dept will be looking for the defective part before they consider reimbursing you, so be sure before you remove it its the problem.
    15 535d 313bhp
    VCDS HEX V2
  8. Re: knocking noise coming from front wheel
    Dec 2010
    Chester
    Exactly the same symptoms as mine and I was convinced it was a CV but a local indi looked over it and could find nothing wrong. As there's no wobble/vibration etc I'm going to see if the symptoms develop or get worse and hope that makes a diagnosis easier. It's driving, handling and braking perfect so I'm a bit stumped.
  9. Re: knocking noise coming from front wheel
    May 2011
    Ireland
    Quote Originally Posted by haytch75 View Post
    Yea thats exactly the same as mine, tink ill do the same and see if it gets worse...
  1. Knocking Noise coming from passenger side front wheel..!! Help
    By Louis 73 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-03-2021, 02:26 PM
  2. Knocking noise coming from engine
    By guymansbridge in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2010, 08:19 PM
  3. Question Knocking noise near front wheel
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2009, 05:13 PM
  4. Knocking Coming from the front of the car
    By 1kky in forum Bora - 1998 - 2005
    Last Post: 21-01-2009, 02:37 PM
  5. knocking coming from front pass
    By michaelhook37 in forum Golf MK3 - 1993 - 1999
    Last Post: 23-10-2008, 06:13 PM
