Thread: Do i need a security code for VAG COM?
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
  1. Do i need a security code for VAG COM?
    kevshek Guest
    Hi all,
    Youll have to excuse my ignorance as im new to this whole concept. Basically, im having cruise control fitted onto my Golf Plus, not through a dealer. The garage has access to some form of VAG COM but they have told me that they will need a security code in order to make any adjustments, such as activating Cruise Control, and this can only be gained from the dealers.
    Is this true?
    Ive made some enquiries with a local dealer who dont have a clue about what im refering too. They say they just hook the car up to the computer and dont need a security or "Master Code" Could this be due to them being actual dealers using geniune equipement?
    Can any clarify what i need in order for the non dealer garage to sucessfully hook up to my Plus.
  2. Re: Do i need a security code for VAG COM?
    Norfolk
    Do the garage have a genuine copy of VCDS and is it up to date. Really you should post an autoscan from the car. I know that is a problem as the equipment isn't yours. Perhaps they can scan the car and give you the log on a usb drive so that you can upload it here. I am surprised the garage don't know how to use the equipment.
  3. Re: Do i need a security code for VAG COM?
    kevshek Guest
    Ive just spoken to them, they have the most up to date, full version of VCDS but say in the past, they have come across this problem with VW's when accessing the ECU. Getting a scan shouldnt be a problem, ill see when i get get there and have it done. Maybe tomorow. Is the scan file a document file i can copy n paste?
  4. Re: Do i need a security code for VAG COM?
    Norfolk
    Yes. It will be a log generated in notepad as a .txt
  5. Re: Do i need a security code for VAG COM?
    kevshek Guest
    ok. ive arranged for a go in the morning and will report back. without doing anything to the car as such, is there anything i can attempt to see if changes can be made without this code i may or may not need? as a tester in prep for the actual cruise control installed.
  6. Re: Do i need a security code for VAG COM?
    Norfolk
    Nothing to see but the log will show how their copy of VCDS is set up. From that I may be able to suggest what to do.
  7. Re: Do i need a security code for VAG COM?
    kevshek Guest
    Ok, heres the results of this mornings scan. Afterwards, we cleared all the errors. As ive only had the car a few weeks, the history in the car is all new to me too. Next time we connect to the VCDS we can tell if there is any ongoing issues that need address.
    Saturday,07,May,2011,09:59:51:37015
    VCDS Version: Release 10.6.3
    Data version: 20101206
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZ7W610580 Mileage: 127520km/79237miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 021 KS HW: 03G 906 021 KS
    Component: R4 2,0L EDC 000SG 9187
    Revision: --H06--- Serial number: VWZ7Z0G8093406
    Coding: 0000072
    Shop #: WSC 01392 785 00200
    VCID: 7AF01A984C59
    1 Fault Found:
    006481 - Radiator Fan 2 (V177): Movement Restricted / Jammed
    P1951 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 6
    Mileage: 126906 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 21:05:08
    Freeze Frame:
    RPM: 1512 /min
    Speed: 48.0 km/h
    Load: 19.2 %
    Voltage: 14.29 V
    Bin. Bits: 11000000
    Temperature: 90.9°C
    Duty Cycle: 14.9 %
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
    Component: ESP FRONT MK60 0101
    Revision: 00H11001
    Coding: 0023282
    VCID: 73EE37BC6B33
    1 Fault Found:
    01435 - Brake Pressure Sensor 1 (G201)
    012 - Electrical Fault in Circuit
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 FT HW: 1K0 820 047 FT
    Component: Climatic PQ35 141 0909
    Revision: 00141027 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 7BFE1F9C4363
    No fault code found.
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
    Component: Bordnetz-SG H52 2002
    Revision: 00H52000 Serial number: 00000006868782
    Coding: E5890F2700041800470A00000F00000000085D035C0001
    Shop #: WSC 01367 785 00200
    VCID: 6CDC2CC0360D
    Part No: 5M0 955 119 B
    Component: Wischer 080307 020 0501
    Coding: 00038805
    Shop #: WSC 01367
    Part No: 1K0 955 559 AD
    Component: RLS 050307 014 1201
    Coding: 06500389
    Shop #: WSC 01367
    2 Faults Found:
    01518 - Bulb for Back-Up Lights; Left (M16)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 121
    Mileage: 127334 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.10 V
    ON
    ON
    OFF
    OFF
    OFF
    00979 - Lamp for Low Beam; Right (M31)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 122
    Mileage: 127346 km
    Time Indication: 0
    Date: 2005.09.13
    Time: 31:63:63
    Freeze Frame:
    ON
    Voltage: 12.00 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 1K AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD1496H0
    Coding: 0012619
    Shop #: WSC 01373 785 00200
    VCID: 3D7AD1841DF7
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD
    Component: J0527 638 0070
    Coding: 0002002
    VCID: 75EA09A46547
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No SW: 1K0 920 973 B HW: 1K0 920 973 B
    Component: KOMBIINSTRUMENT VDD 1610
    Revision: V0003000 Serial number: VWZ7Z0G8093406
    Coding: 0003403
    Shop #: WSC 00875 210 92206
    VCID: 2C5CECC0F68D
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 K HW: 1K0 907 951
    Component: J533__Gateway H04 0021
    Revision: H04 02 Serial number: 180307F1002305
    Coding: 3D3F034007009003
    VCID: 2F66FBCCC79B
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VDD 1610
    VCID: 2C5CECC0F68D
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 005 0990
    Coding: 0000692
    VCID: 3874C09032D5
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 L
    Component: EPS_ZFLS Kl.070 H07 1806
    Shop #: WSC 00000 028 00001
    VCID: 356AC9A425C7
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0203
    Revision: 00020000 Serial number: 00000000000000
    Coding: 819002005103087F2D04840570085FC690FC00
    VCID: 830EE77CBB93
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 951 178 A
    Component: Neigungssensor 003 0203
    Component: Innenraumueberw.003 0203
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
    Coding: 0000692
    VCID: 3972C59409DF
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 5M0 035 186 C
    Component: Radio GR0 034 0033
    Revision: 0003404S Serial number: VWZ2Z2G3323752
    Coding: 0010400
    VCID: 2C5CECC0F68D
    5 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    00870 - Bass Speaker Front Left (R21)
    011 - Open Circuit - Intermittent
    00871 - Bass Speaker Front Right (R23)
    00872 - Bass Speaker Rear Left (R15)
    00873 - Bass Speaker Rear Right (R17)
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
    Component: Tuer-SG 005 0914
    Coding: 0000144
    Shop #: WSC 01392 785 1012552
    VCID: 3874C09032D5
    Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
    Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
    Coding: 0000144
    VCID: 3972C59409DF
  8. Re: Do i need a security code for VAG COM?
    kevshek Guest
    Martin, while looking about on the VDCS program, i was shown the bit about the pass code. Its from the Coding Login and it brings up a screen like this.
    ive been told that without the code, you cant make adjustments, but while search the threads, ive seen one about an Audi using the code 12345.
    We also had a look about to see where the option was for the cruise control but couldnt find it. Could this be because the stalk isnt installed yet?
  9. Re: Do i need a security code for VAG COM?
    May 2007
    knee deep in clunge
    14 Post(s)
    wrong login in search dis and cruise retro fit on this forum for all the info you need to encode address 16 and enable cruise in address 01
    go to address 01 enter 11463 for login and then go to address 16 change bye 4 for cruise
    make sure your vcds has a workshop name and number in the identification window to allow code changes for control units
  10. Re: Do i need a security code for VAG COM?
    kevshek Guest
    Quote Originally Posted by a8 tech View Post
    Thanks for helping A8, but im a total noobie and have no idea what your refering too. Could you elaborate a bit on the steps, and i will show this to the tech doing it.
  1. Question How to enter the security code for VW RCD310?
    By Wantage Will in forum In Car Entertainment
    Last Post: 18-04-2010, 03:31 PM
  2. Radio Security Code
    By hotjamesall in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-02-2010, 05:59 PM
  3. Please Help Security code for key
    By Decoy in forum Ibiza - Cordoba
    Last Post: 06-10-2009, 02:00 PM
  4. concert security code
    By bez101 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2008, 11:18 PM
  5. Audi Concert Security Code
    By ChameleonS4 in forum New Member Introductions
    Last Post: 13-05-2008, 05:20 PM
