Thread: Cam cover oil leak
  1. Cam cover oil leak
    Audi 80 auto 1984cc ABT engine.
    During a part rebuild late last year I used the Audi rubberlike cam cover gasket with the small collar inserts. All surfaces were degreased with proffessional cleaner before assembly and oil leaks were almost immediate. I removed the cover and gasket, cleaned everthing again and rebuilt it all using Hylomar on all surfaces, This has given me about five months of use with a nice clean engine, but, I have just noticed a trace of oil from the front o/s end of the cover. Please, what is the secret of fitting the gasket to keep the oil inside, and not have any dribbles ?
    Regards Dos.
  2. Re: Cam cover oil leak
    134 Post(s)
    2021 Post(s)
    I fit those gaskets covered with copious amounts of black RTV and particularly around the cam seal hump and rear ½ moon fitting.
  3. Re: Cam cover oil leak
    Many thanks Crasher, I'll get some and go over the job again. It was really nice to have a clean and dry engine even if it was only for a few months.
    Kind regards Dos.
  1. Oil coming out of cam cover breather
    By tony2311 in forum Ibiza - Cordoba
    Last Post: 28-06-2010, 01:22 PM
  2. Engine oil leak - Valve cover gasket
    By wheelywonderful in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-04-2009, 06:41 PM
  3. 2.8 v6 30v cam cover help
    By clive30v in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-04-2009, 06:56 PM
  4. Oil leak rocker cover
    Last Post: 03-10-2008, 10:51 PM
  5. water leak from cam cover...help please
    By steff in forum Golf MK4 - 1999 - 2004
    Last Post: 24-09-2007, 10:04 AM
