Thread: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
Results 1 to 10 of 12
  1. Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Jan 2009
    york
    hi my audi a4 1.9tdi has recently started with this problem ??
    when i start the car fine .. but when i turn the lights on the esp /abs and brake light come on and the brake light starts flashing ???
    now.. it only does it now and then but more often than not dont understand it?
    but i fitted hids about a month ago which i though it maybe them but it just doeesent add up please help....!!! ??
  2. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Jan 2009
    york
    please someone dont know whether its my brakes or to do with my lights...
    Audi A4 1.9tdi 130 sport!! - stealth!!
  3. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Mar 2011
    Kendal Cumbria UK
    You would have to get a code read, but i have heard of HID kits without canbus wiring adaptors/ballasts causing this kind of problem. try taking the kit off and see if the faults stop.
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  4. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Mar 2011
    mansfield, uk
    Mine does it also and i have aftermarket hid's fitted so i presume its them causing the fault, i find if i click to side lights then click to headlights it doesnt do it. If i click straight to headlights in one quick movement they all light up everytime. What are these canbus wiring adapters?
  5. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Mar 2011
    Kendal Cumbria UK
    I've no idea what's in them I know mine have them, just a box in the wire to the ballast. Mine interfere with the radio more than anything!
    Dan
  6. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Jan 2009
    york
    Y RADIO SIGNAL IS CRAP! permanenly !
  7. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Jan 2009
    Ilkley, West Yorkshire, United Kingdom
    Sounds crazy I know, but are your brake light bulbs ok?
    Both my brake light bulbs were blown on my A6 and iirc it lit the ESP/ABS light on the cluster.
  8. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Jan 2009
    york
    yes checked every bulb they are fine mate
  9. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Mar 2011
    Kendal Cumbria UK
    Id get the codes read mate. Is there anyone near you with VAGCOM? Its the best way to check whats causing it, aside from just unplugging your HID kit and going back to OEM to try.
    Dan
  10. Re: Brake warning light..esp.. and abs coming on ?? when lights are turned on ?....
    Mar 2011
    mansfield, uk
    I know this is an old thread but thought id share some info.... i had this problem and after reading several posts/threads on different forums i stumbled accross the cure
    My nearside HID ballast was just under the headlight which interfered with the ABS pump which was not too far away, the simple fix was to earth the ballast to the body which shielded it and stopped the fault (2 month problem free).
    So to all that have the ABS, ESP fault when turning your lights on, earth your passenger ballast to the body and enjoy turning your lights on without the dash going crazy ;-)
  1. ABS/ESP warning lights on. Brake pressure switch.
    By Moose man in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-01-2011, 09:56 PM
  2. Please Help Passat 2.0S 2002 Brake Lights and Flat Battery with intermittent ESP / ABS warning light
    By tweever in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-10-2009, 01:50 PM
  3. Please Help ABS, ESP and Handbrake warning lights coming on!
    By 1958 harry in forum Beetle 2000-
    Last Post: 05-03-2009, 08:12 PM
  4. Please Help ESP, ABS and BRAKE Warning Lights!
    By Uxair in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2009, 10:39 PM
  5. ABS and ESP Warning Light Illuminated after Pressing Brake Pedal
    By Tub Thumper in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2008, 09:50 PM
