Thread: ABC V6 Temp sensor, please advise
  1. ABC V6 Temp sensor, please advise
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Hi gang , after various chats with Crasher and other members aswell as other tradespersons, I am keen to know if the temp sensor mentioned as being a potential offender in relation to my emissions fail, is the plug in affair located just above the bottom hose on the radiator on the drivers side of the rad (right hand drive ).
    If this is not the same item, where is it located and roughly how much would one cost?
    '95 coupe 2.6 abc v6 manual front drive
    I have just replaced the rad and the sensor in it with an item from a dissmantlers and believe the sensor to be ok as the fans trip in and out when the gauge shows around 90 degrees c.
    Or is this sensor just for the fans and gauge and therefore another one lurks elsewhere
    Hope that makes sense
    Stuart
  2. Re: ABC V6 Temp sensor, please advise
    Gwent
    answered in the other thread!
    2001 Passat Sport tdi 130hp
    1990 Audi coupe 20v x 2
  1. abc oil temp soaring
    By logicalgnu in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-06-2010, 02:22 PM
  2. abc crank speed sensor
    Last Post: 30-03-2010, 11:18 PM
  3. Coolant Temp Sensor & Temp Gauge
    By amz in forum Golf MK4 - 1999 - 2004
    Last Post: 30-03-2009, 10:19 AM
  4. IAT (Intake air temp) and Coolant Temp sensor location
    By yep.its.jay in forum Audi A3 - Archive Topics
    Last Post: 16-03-2009, 10:33 PM
  5. Coolant temp sensor advise please
    By Eugheugh in forum Passat - Archive Topics
    Last Post: 20-09-2007, 08:11 AM
