Thread: audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
  1. audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
    Mar 2010
    pontefract
    hi all, my rear spring has broken on my 1995 audi coupe quattro 2.8v6 and i'm having an absoloute nightmare trying to find some replacement springs for it, as i'm told there was only 200 of these cars made and no one does parts for it. does anyone know where i can get some from???????????
    thanks very much,
    thicky
  2. Re: audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
    chairman_mo Guest
    http://cgi.ebay.co.uk/HD-REAR-COIL-S...item4cf1836e23
    It says it is what you are after, but I can make no comment on their authenticity or suitability for your vehicle
  3. Re: audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    Would it have to be 2.8 springs or why not any of the coupe quattro, or even a set up from the S2
  4. Re: audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
    chairman_mo Guest
    If you can identify the Audi part number your local dealer may be able to advise any other model where the 2.8 springs are used. I would be willing to bet they are used on another model of similar vintage for example an A4/6/8.
    As fourringsrus suggests use the springs off another model. A 2.6 and 2.8 use the same engine and the weight difference is likely to be minimal (the addition of a 4wd system - say 50-100kgs) and I wonder if they use the same rear springs.
    If you really want to get technical if you can find the length and spring rate you should be able to pick up a similar spring from a specialist supplier.
  5. Re: audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
    Oct 2009
    10 Post(s)
    Quote Originally Posted by chairman_mo View Post
    I would go as far as to suggest that a full set of lowered set up would be as easy to find for quite a sensible figure, again dont forget the S2 is essentially a quattro coupe, unless I'm being simplistic
    Stuart
  6. Re: audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
    chairman_mo Guest
    Or 2.8 cabrio springs
  7. Re: audi coupe quattro 2.8 v6 rear springs??????????????????????????????????????????? ??????????
    Jan 2011
    bicester england
    i have s2 springs all round on my 2.8v6 quattro coupe, its a nice easy job to do.
  1. A4 b5 1999 turbo quattro sport rear springs
    By Quattros in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-01-2011, 01:04 PM
  2. A4 Quattro Avant Rear Springs...sport chassis
    By aliw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2010, 01:25 AM
  3. A3 1.8T quattro rear springs
    By Andy G in forum Audi A3 - Archive Topics
    Last Post: 29-04-2007, 12:31 PM
  4. 1986 Ur-Quattro coupe rear diff
    By adey26 in forum Archive posts
    Last Post: 05-06-2006, 10:05 AM
  5. Audi Coupe Quattro
    By Pooh_r in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-05-2006, 08:32 PM
