Thread: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
Results 1 to 10 of 20
  1. HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    Feb 2011
    manchester uk
    2006 audi a6 2.0 tdi se avant anybody please shed light on my problem vagcom says phone not installed and states everything else ok dont know where to start have thought of replacing phone ecu under passenger seat but dont want to be throwing good money after bad is there a way i could do a test to make sure it is actually phone unit to blame beacause satnav worked fine before i tried a firmware update and now it just wont initialise and as though that isnt bad enough every 5 or so minutes whatever i am listening to be it radio or cd the whole MMI restarts
    Chassis Type: 4F0
    Scan: 01 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53 56
    61 62 72 77
    Mileage: 137710km/85569miles
    01-Engine -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    1E-Media Player 2 -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    77-Telephone -- Status: Cannot be reached 1100
    Address 01: Engine Labels: 03G-906-016-BLB.lbl
    Part No SW: 03G 906 016 HS HW: 03G 906 016 HS
    Component: R4 2,0L EDC G000SG 9673
    Revision: --H02--- Serial number:
    Coding: 0000072
    Shop #: WSC 00408 210 87187
    VCID: 7BFE721A438D
    No fault code found.
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 4F0-910-517.lbl
    Part No SW: 4F0 910 517 K HW: 4F0 614 517 K
    Component: ESP 8.0 front H05 0090
    Revision: 00000000 Serial number: 00000000000000
    Coding: 0020855
    Shop #: WSC 02325 785 00200
    VCID: 2C5C8146F663
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000419919
    Coding: 0000145
    VCID: E3CEAA7A5B3D
    Part No: 4F0 910 131 D
    Component: FBSAUDIC6 EZS H45 0080
    Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H39 0040
    Address 07: Control Head Labels: Redir Fail!
    Part No SW: 4F0 910 769 B HW: 4F0 035 769 B
    Component: MMI Cockpit H55 0010
    Revision: C51500BE Serial number: AUZ6Z3F4P321K1
    Coding: 0100002
    Shop #: WSC 02323 785 00200
    VCID: 2C5C8146F663
    Part No: 4F0 910 609 E
    Component: Bedienteil MMIC6H03 0050
    Address 08: Auto HVAC Labels: 4F0-910-043.lbl
    Part No SW: 4F0 910 043 HW: 4F2 820 043 H
    Component: KLIMABETAETIGUNGH12 0170
    Revision: 00000030 Serial number: 00000000261522
    Coding: 0001300
    VCID: DBBE929A634D
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 D HW: 4F0 907 279
    Component: ILM Fahrer H15 0190
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0000101
    Shop #: WSC 02335 785 00200
    VCID: 2A50875EFC97
    Part No: 4F2 910 113
    Component: Wischer AudiC6 H04 0150
    Coding: 00062736
    Shop #: WSC 02335
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH12 0090
    Coding: 00141886
    Shop #: WSC 02335
    Address 0E: Media Player 1 Labels: Redir Fail!
    Coding: 0100002
    VCID: 2C5C8146F663
    Address 15: Airbags Labels: 4F0-910-655-8R.lbl
    Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
    Component: 4E AIRBAG AUDI8RH29 0280
    Revision: 08H29000 Serial number: 0037LD0EG7E9
    Coding: 0013381
    VCID: 29527852F991
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H07 0230
    Revision: 00H07000 Serial number: 90026061180457
    Coding: 0102042
    VCID: E6C8B36EA80F
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
    Part No SW: 4F0 910 900 A HW: 4F0 920 950 L
    Component: KOMBIINSTR. M73 H12 0660
    Revision: 00000000 Serial number: 4RA75A346
    Coding: 2308443
    Shop #: WSC 00012 000 00000
    VCID: 1E385B8EB0DF
    Address 19: CAN Gateway Labels: 4F0-910-468.lbl
    Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
    Component: Gateway H11 0070
    Revision: 11 Serial number: 130080642681EC
    Coding: 6CEE53C43B3104
    Shop #: WSC 02334 785 00200
    VCID: 27567E6AEF85
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBF8105835
    Shop #: WSC 00000 000 00000
    VCID: 1C3C5186A6C3
    Address 37: Navigation Labels: Redir Fail!
    Coding: 0100002
    VCID: 2C5C8146F663
    Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
    Component: TSG FA H12 0120
    Revision: 00000000
    Coding: 0003610
    Shop #: WSC 02327 785 00200
    VCID: 2C5C8146F663
    Address 46: Central Conv. Labels: 4F0-910-289.lbl
    Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
    Component: Komfortgeraet H22 0170
    Revision: 01700022 Serial number: 01012961260000
    Coding: 0000763
    VCID: 2E588B4EC07F
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 4F0 910 177
    Component: Innenraumueberw.H01 0020
    Address 47: Sound System Labels: 4F0-910-223-AS.lbl
    Part No SW: 4F0 910 223 C HW: 4F0 035 223
    Component: Amp.-ASK H10 0320
    Revision: 36S00001 Serial number: 00405060267273
    Coding: 0000101
    VCID: 1E385B8EB0DF
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 A
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000230390
    Coding: 0001104
    VCID: DEB89B8E705F
    Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
    Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
    Component: TSG BF H12 0120
    Revision: 00000000 Serial number: I(V
    Coding: 0003610
    VCID: 2C5C8146F663
    Address 53: Parking Brake Labels: 4F0-910-801.lbl
    Part No SW: 4F0 910 801 A HW: 4F0 907 801
    Component: EPB CA3C0040 H03 0040
    Revision: --H03---
    Coding: 0000111
    Shop #: WSC 00000 785 00200
    VCID: 1E385B8EB0DF
    Address 56: Radio Labels: Redir Fail!
    Coding: 0100002
    VCID: 2C5C8146F663
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000023742
    VCID: 234E6A7A9BBD
    Part No: 4F0 915 105 C
    Component: von VA0 1604200152
    Coding: 344630393135313035432056413031363034323030313532
    Shop #: WSC 00000 384 00290
    Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
    Component: TSG HL H21 0050
    Coding: 0003074
    VCID: 2E588B4EC07F
    Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
    Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
    Component: TSG HR H21 0050
    Coding: 0003074
    VCID: 2E588B4EC07F
    Address 77: Telephone
    Cannot be reached
    Control Module Part Number: 4F0 910 468 A
    Component and/or Version: Gateway H11 0070
    Optical Bus Diagnostic : 3dB Attenuation
    Controller Electrical Optical
    19-CAN Gateway OK OK
    07-Control Head(Std Navi) OK OK
    0E-Media Player 1 ERROR ERROR
    1E-Media Player 2 OK OK
    77-Telephone ERROR ERROR
    47-Sound System OK OK
    56-Radio ERROR ERROR
    37-Navigation ERROR ERROR
    46 Post(s)
    Clear fault codes and scan again. Look in your boot on the left hand side and open the panel to see if the electronics are wet.
  3. Re: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    west yorkshire
    if it was working before the update, suggests the firmware update may have caused this. what was the SW version of the mmi before the update, and to what firmware SW version have you done this to? Where have you got the disks from, or downloaded them? its a start..
  4. Re: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    Feb 2011
    manchester uk
    have cleared faults twice even from individual modules and still all same faults come back checked boot behind panel all safe and dry dont know firmware before update but was trying to install 4F0906961T many thanks for your replies
    46 Post(s)
    I done a google on that part number and it's the CDs for MMI basic? Do you have a colour screen in the middle of the dash above the heater controls?
  6. Re: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    west yorkshire
    what is your set up, mmi high with cd sat nav/ dvd sat nav/ 6 disk changer? where did you get the update cd/dvd from? how many cd/dvd are they?
  7. Re: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    Feb 2011
    manchester uk
    i Have MMI basic plus (monochrome red/black) i have 6 disc changer and single disc satnav (CD) in glovebox i got download from http://gpsunderground.com/forum/audi...ersion%5D.html i installed the map okay then tried the language support thats when all my problems started many thanks for your time to reply
  8. Re: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    west yorkshire
    re install but leave the lanuage alone, if everythig is ok, then the language cd is corrupt. these download sites can offer someting for free, but not always reliable, maybe the language cd is corroupt.. thats what i'd try first.
  9. Re: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    Feb 2011
    manchester uk
    have tried reinstall many times but it wont and every time i start car satnav just says 'navigation is initialising please wait' no matter how long i wait be it minutes or hours i could live without the satnav its the annoying MMI restart evry 5 minutes or so that is wrecking my head
  10. Re: HELP PLEASE telephone and satnav not working and radio and cd restart every 5-10 minutes
    west yorkshire
    reset the mmi with vcds, controller 07, channel 111, input a value of 1
    or press on console press SETUP, BIG KNOB, top RIGHT soft button.
  1. A4 B7 2.0t stalled on pull away wont restart untill 30+ minutes
    By trapster in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-04-2011, 12:58 PM
  2. Replies: 1
    Last Post: 06-07-2009, 11:04 PM
  3. How to get my SatNav working?
    By IainC in forum In Car Entertainment
    Last Post: 28-03-2009, 06:34 PM
  4. RCD 300 Radio telephone connections
    By Big John in forum Golf Plus
    Last Post: 09-09-2008, 09:06 PM
  5. Playing your MP3 player/SatNav through your Beta etc VW radio
    By Julian Joyce in forum Archive posts
    Last Post: 10-09-2007, 09:28 AM
