Thread: Limp mode loss of turbo boost
Results 1 to 10 of 16
  1. Limp mode loss of turbo boost
    Jul 2009
    warrington england
    Hi I hope someone can Help me.
    My turbo goes into limp mode.
    I know the turbo is ok ive just replaced it with a new unit from audi, its also had a new air meter again from audi and all the vac lines replaced, at present the egr valve is disconected (pipe pluged) I'm looking for ideas to try next thanks.
  2. Re: Limp mode loss of turbo boost
    Sep 2008
    chester
    17 Post(s)
    Get it scanned for codes,find out why its going to limp.
  3. Re: Limp mode loss of turbo boost
    Jul 2009
    warrington england
    Ive scanned it no codes
  4. Re: Limp mode loss of turbo boost
    134 Post(s)
    2009 Post(s)
    I can’t see how it is going into limp mode without leaving a code, that is not possible. What are you reading the codes with?
  5. Re: Limp mode loss of turbo boost
    Jul 2009
    warrington england
    vag-com a shareware copy the only fault i get is the left engine mount
  6. Re: Limp mode loss of turbo boost
    Sep 2008
    chester
    17 Post(s)
    Was it a new actuator.
  7. Re: Limp mode loss of turbo boost
    134 Post(s)
    2009 Post(s)
    If the engine ECU is going into limp I have never seen this without a fault code. Can you describe how you think it is going into limp mode?
  8. Re: Limp mode loss of turbo boost
    Jul 2009
    warrington england
    Yes it was a new actuator it was complete new turbo from audi.
    It goes in to limp mode after ive driven it at normal speed and then demand power say to join the motorway.
    I know the turbo and air meter are ok, would having the EGR valve disconected and the vac pipe pluged cause this to happen and would it be worth changing the intake pressure sensor.
    Just thought I run a K&N panel filter.
    Thanks for all the Help this is driving me mad.
    A4 Avant 1.9 TDI Sport 130 awx engine.
  9. Re: Limp mode loss of turbo boost
    Jan 2009
    Birmingham
    36 Post(s)
    If you are getting any lights on the dash when it goes into limp mode then you will get a code when you scan it if no lights then when it goes into limp mode don't turn the key on and off and scan it in limp mode you will a code
  10. Re: Limp mode loss of turbo boost
    Jul 2009
    warrington england
    I get no lights on the dash.
    I have driven it tonight with my laptop conected when it went in to limp mode I scaned for codes this is what it came back with.
    - 17994/P1586/005510 - Engine Mount Solenoid Valves (N144/N145): Short to Plus
    - 17965/P1557/005463 - Charge Pressure Control: Positive Deviation
    - 18043 (i can't find what this is)
    I hope someone can help.
  1. Audi A4 1.9 TDI (1999) - power loss...limp mode?
    By k3t4n in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-12-2019, 05:16 PM
  2. Please Help 1.9 tdi power loss/ limp mode
    By geo_855 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2011, 08:43 AM
  3. Loss of power/Limp mode?
    By tyberwan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-10-2009, 04:59 PM
  4. 1.9TDI Quattro Boost Cutting out then Limp Mode
    By rallyman in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-07-2009, 08:31 PM
  5. Please Help boost cutting out and limp mode
    By 90karl90 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-05-2009, 06:18 PM
