Thread: Advanced Measuring Blocks
  1. Question Advanced Measuring Blocks
    Hi All,
    Just when I was getting used to using Measuring Blocks, I find them greyed out on my Audi A4B8.
    Does anyone know the LOC groups, in Adv Meas Blks so as to measure Fuel Trim.
    The only info I can get on Adv Meas Blks is from Ross-Tech`s introduction page to Measuring Blocks.
    Still being new to VCDS, I found Meas Blks really useful, Adv Meas Blks has me concerned in relation to what LOC numbers I may require for further testing.
    All replies much welcomed. Thank you in advance
    Regards John
  2. Re: Advanced Measuring Blocks
    May 2007
    knee deep in clunge
    14 Post(s)
    engine code and year
  3. Re: Advanced Measuring Blocks
    Ahhh A8 Tech,
    Always the gentleman.
    Code CDNC, May 2010, 2.0L Petrol Quattro S tronic. ( Australia )
    I bless your replies
    Many thanks
    John
  4. Re: Advanced Measuring Blocks
    May 2007
    knee deep in clunge
    14 Post(s)
    Hi John
    Unfortunately the software I use will not allow me to extract the mvb values as it needs to be connected to the vehicle but all is not lost.
    Use the obd function as fuel trim and lambda values will be displayed and you should be able to work out what's going on.
  5. Re: Advanced Measuring Blocks
    Ambler, PA, USA
    Quote Originally Posted by johnvw View Post
    Hi All,
    Regards John
    My guess is the engine you have uses the UDS protocol and does not have any "measuring blocks". In '08, the VAG people began the move to a new scheme known as UDS/ODX and that scheme does not have measuring groups and blocks. It has up to as many as 1024 live values that can be monitored. These are presented in the drop down window of the Advanced Measuring values. So, rather than blame the tool, write to our friends in the VAG group.
    Having written all this, what exactly is the issue? Can you not see the live values in the advanced measuring values function? If not, then I have to ask, what version of VCDS and where did you buy your interface?
  6. Re: Advanced Measuring Blocks
    Thank you A8 tech and Bruce the Bear,
    I had composed a lengthy reply but some how was disabled before I could post.
    I will try again but not tonight.
    Regards John
  1. Audi 2.0 tdi fuel injectors -measuring blocks
    By herts62 in forum VCDS - General Questions
    Last Post: 11-03-2011, 02:08 PM
  2. Measuring Blocks", and check the lambda sensor reading
    By gpaul in forum VCDS - General Questions
    Last Post: 13-04-2010, 05:05 PM
  3. Audi A4 B8 2.0tdi Measuring Blocks
    By sabingli in forum VCDS - Help Requests
    Last Post: 11-07-2009, 07:44 AM
  4. Measuring Blocks N/A
    By A4Ade in forum VCDS - General Questions
    Last Post: 04-06-2008, 11:18 AM
  5. How to log blocks?
    By Sloggs in forum VCDS - General Questions
    Last Post: 02-12-2007, 07:10 PM
