Thread: rear door wouldn't lock from inside (using 'lock' button)
  1. Angry rear door wouldn't lock from inside (using 'lock' button)
    Mar 2009
    My rear driver door cannot be locked from inside by central locking button. It locks and then unlocks itself right away and can only be locked by physically pushing the pin down.
    All doors lock with a remote and by turning a key in the lock from outside the vehicle.
    Does anyone know how to sort this annoying thing out? Thanks.
  2. Re: rear door wouldn't lock from inside (using 'lock' button)
    Sep 2009
    Lincoln, England
    6 Post(s)
    When you open the door, does the interior lamp/puddle lamp work? I'm going to guess at no. If this is the case, I suggest you check the wiring to the ccu from the door, and also the microswitch in the door catch assembly.
    Daz
  3. Re: rear door wouldn't lock from inside (using 'lock' button)
    Mar 2009
    Quote Originally Posted by stig414 View Post
    Daz
    Thanks for your help Daz. Unfortunately (or fortunately) the lights work as they are supposed to. I had a wet driver's side carpet problem during winter which was eliminated and I have checked the CCU and the cables around it at that occasion. I didn't have the door locking problem at that time so didn't check the driver's side. Will do it today or tomorrow hopefully, if my girlfriend doesn't find anything 'better' for me to do
    Just found this article:
    http://www.taligentx.com/passat/main...lockmechanism/
    Do you think it may be my problem too?
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. Rear door lock probs.
    By burnleywhite in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-10-2010, 09:29 PM
  3. Question where to get rear door lock
    By swany99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-10-2008, 10:49 PM
  4. Rear door lock
    By Andy N.I in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-01-2008, 06:40 PM
  5. A4 Avant Rear door lock
    By biscas in forum Audi A4 - Archive Topics
    Last Post: 18-11-2007, 01:46 PM
