Thread: Aux In Problem RCD 300
Results 1 to 9 of 9
  1. Aux In Problem RCD 300
    daniel408 Guest
    Hey guys,
    I bought the aux in kit from VW and installed it my self as I did put my iPod kit in myself. I've wired it in and stuck everything back together but when you press the cd button twice it comes up with "NO CDC". I have the rcd 300 with the silver buttons and the official kit from VW.
    Any ideas?
    Dan
  2. Re: Aux In Problem RCD 300
    DSG4ME Guest
    Take it back and get a refund, then order a Connects2 CTVVGX004 adapter £30 from Dynamic Sounds, works first time.
  3. Re: Aux In Problem RCD 300
    daniel408 Guest
    Quote Originally Posted by DSG4ME View Post
    Sorted mate. I just had to put a different code in the radio. We had to trick the radio into thinking it had a cd changer. £10 from an independent or £50 from vw. Robbing bar stewards!!!!
  4. Re: Aux In Problem RCD 300
    DSG4ME Guest
    Quote Originally Posted by daniel408 View Post
    I thought that might be the case, well for future reference the CTS2 unit works like a charm, straight in and all good to go, sound is good as well.
  5. Re: Aux In Problem RCD 300
    Sep 2011
    Aberdeen
    Hi Daniel, can you remember what it was you had to do to fool the unit into thinking the CD changer was attached? I intend to homebrew an aux in cable.
  6. Re: Aux In Problem RCD 300
    Apr 2012
    somerset
    Hi guys, I've also got the rcd 300 and have just bought the connects2 aux adapter. I thought i could just follow the instructions and get it to work but i dont understand where it is telling me to put the black wire? I think its the 'earth cable'? Sorry I dont really know what im on about, just wondering if someone could help me out. The diagram just shows it going into a small black hole on the back of the headunit.
    Thanks,
    Alex
  7. Re: Aux In Problem RCD 300
    Apr 2012
    somerset
    Hi mate, i seen that you had the same message as me a while back about the 'cdc'. I read that you found someone to give you a code for it? I dont suppose you tell me where you got your code from? I have just installed the connects2 aux adapter and its showing 'cdc' when i press cd twice.
    Many thanks
    Alex
  8. Re: Aux In Problem RCD 300
    Jul 2012
    Ireland
    Hi Daniel, i am trying to install Connects2 Aux ipod kit and i get the same error as you, when i press the cd twice, the screen says NO CDC, i think you got this issue fix, if you can kindly let me know how you got this fixed, i live in dublin and i was trying this on passat 2007 fsi 1.6 car, thank you
  9. Re: Aux In Problem RCD 300
    daniel408 Guest
    Eh up Dilber,
    I went to my local independent VW garage (not a *******) and asked him to have a look at the settings on the vag com. He had to change the code for the radio to tell it that there wasn't a CD changer "CDC" and there was now a AUX. my code was in my manual but the software gives you a "chat bubble" that gives you a guide to what you have to change. The garage should know what they are doing. It cost me £10.
    Hope this helps.
  1. Electrical problem. i bet nobody faced such a problem
    By hamma in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 14-12-2010, 05:22 PM
  2. Puzzling coolant temperature problem (not just a sender problem)
    By bartonthesparta in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 06:58 PM
  3. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  4. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
  5. Air Conditioning problem or display problem?
    By Doug999 in forum Archive posts
    Last Post: 02-01-2008, 11:59 PM
