Thread: Fault P0238, P1556, P1103, P1136, P0011
  1. Fault P0238, P1556, P1103, P1136, P0011
    Nov 2010
    England
    So, stuck the car on Vag-com prior to fitting my new crank position sensor and got the following errors. (The car is now running smooth as silk thanks to new sensor and manifold breather pipe but a little concerned about these codes).
    1.8T Quattro Saloon.
    P0238 - Turbocharger Boost Sensor (A) Circ. High Input. Intermittent.
    P1556 - Charge pressure control value below lower control limit. Intermittent.
    P1103 - Bank1-Sensor1, Heater Circuit. Performance too low. Intermittent.
    P1136 - Bank1, mixture adaptation (add). System too lean. Static.
    P0011 - A Camshaft Position (Bank1). Timing over-advanced or System Performance. Intermittent.
    Any ideas to any of the faults greatly appreciated thanks peeps as i'm out of my depth now
  2. Re: Fault P0238, P1556, P1103, P1136, P0011
    Apr 2009
    Clear the codes, run the car for a day or two and
    post any codes that come back.
    Regards
    Jim
  3. Re: Fault P0238, P1556, P1103, P1136, P0011
    Nov 2010
    England
    Had the faults cleared after fitting the crank sensor and all is sweet so far so hopefully they were just due to the one fixed problem.
    However the bank1 errors have occured before maybe 2-3 times but are always cleared when the car had another fix (fuel pump, radiator, spark plugs etc) and none of the garages really mentioned them or the cause.
    I must admit she seems very thirsty at the moment!
  1. Please Help Various Faults on A3 2.0tdi
    By Roosterman in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-12-2010, 06:10 PM
  2. concert to rns-e tt 2007
    By wilburforce in forum VCDS - Help Requests
    Last Post: 16-09-2010, 09:53 AM
  3. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  4. dpf fault
    By deutsch in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2010, 02:50 PM
  5. low engine power from cold
    By saabsalltheway! in forum VCDS - General Questions
    Last Post: 30-11-2009, 10:21 PM
