Thread: RCD300 on the way out or just dodgy fm reception?
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: RCD300 on the way out or just dodgy fm reception?
    Scotland/New Mexico
    Big applause to the BBC, the DAB is now working up in the Wetlands and so the one off build is 10% tamed. Shee - it, how I miss my MkI Escort.
  2. Re: RCD300 on the way out or just dodgy fm reception?
    Mar 2009
    York
    sawtooth...
    Yes I do! still left over from my experience! would offer at half price to that one on ebay. PM if interested.
    thanks
    if you want to see it, search for Passat Antenna Unit (or similar) on ebay in the closed listings section. It never sold! Seller name is pauly_t
    ps: the crimped connection you see is the earth lead. it is an active antenna so power is delivered via the central wire of each coax cable.
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  3. Re: RCD300 on the way out or just dodgy fm reception?
    May 2008
    Hi there, I cannot PM you but I sent you a message via Ebay (email).
    Many Thanks for your help, hopefully my radio will soon be restored.
  4. Re: RCD300 on the way out or just dodgy fm reception?
    Mar 2009
    York
    I'll post it off tomorrow to you, you should have black clips that the unit will slide into, and the connections will set in the pre determined gaps in the antenna housing. Just confirm that you do have the crimped earth wire that;s connected to the roof of the passat - I won't need to supply the one that came with the antenna unit in that case...
  5. Re: RCD300 on the way out or just dodgy fm reception?
    May 2008
    I saw 1 crimped black cable so I think I'm good. I assume the antenna cables are identical and that it doesnt matter how they are connected? I just hope that this part will get the radio working!!!
    Will let you know,
    Many Thanks.
  6. Re: RCD300 on the way out or just dodgy fm reception?
    Mar 2009
    York
    Yes it does matter which way they are connected. They are colour coded for a reason. get them the wrong way round and you'll not get AM. That's the easiest way to tell!!
    Hth
  7. Re: RCD300 on the way out or just dodgy fm reception?
    #17
    May 2008
    Thanks for the part it worked a treat.
  1. A6 MMI 3G radio/TP/TMC problem
    By MFGF in forum In Car Entertainment
    Last Post: 05-06-2020, 07:19 AM
  2. Please Help A3 - No radio reception
    By jonnersp in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-12-2010, 10:25 PM
  3. Dension Ice Link Plus - Wiring Config for a RCD300
    By RickT in forum In Car Entertainment
    Last Post: 10-07-2010, 09:25 PM
  4. Please Help RCD300 dreadful reception - MY04 Golf GT Tdi
    By Kav4962 in forum Golf MK5 - 2004 - 2009
    Last Post: 03-10-2009, 05:26 PM
  5. Poor radio reception
    By peterc57 in forum Audi A4 - Archive Topics
    Last Post: 20-01-2007, 11:30 AM
