Thread: I bought VCDS and found an error :(
  1. I bought VCDS and found an error :(
    46 Post(s)
    I bought VCDS from Gendan over the weekend and the hardware arrived this morning and I completed a Auto Scan to see if there were any surprises.
    Everything was fine until this:
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4F9 910 401 HW: 4F0 907 401 C
    Component: 3.0L V6TDI G000AG 0020
    Revision: --H05--- Serial number:
    Coding: 0011372
    Shop #: WSC 02334 785 00200
    VCID: E2C0360C44C9
    1 Fault Found:
    005663 - Glowplug for Cylinder 6 (Q15): Open Circuit
    P161F - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 77943 km
    Time Indication: 0
    Date: 2010.09.03
    Time: 12:15:00
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 12.16 V
    Duty Cycle: 15.0 %
    Temperature: 15.3°C
    Readiness: 0 0 0 0 0
    As im a newbie to the software I dont know how to clear the codes and run a re-scan but im sure i'll pick it up fast.
    Thanks guys
  2. Re: I bought VCDS and found an error :(
    Aug 2010
    London
    I've just got it as well! Been playing with it over the weekend and here's what I found:
    Once you've run the full scan, there's a button labelled 'Clear all DTCs'. This clears the fault codes and then you can rescan.
    If that's the only code you have, it's quicker/easier to just scan that module. If you go into the engine control module and click on 'Fault Codes' there's then a button to clear the saved codes which then rescans the module to see if its an actual problem.
    Hope this helps!
    46 Post(s)
    Thanks I'll keep that in mind and look put for it! I'm like a kid with a new toy atm, just looking around the program to see what it has to offer.
    I'll clear it and run a scan tomorrow
    46 Post(s)
    Cleared the codes and the fault occurred again I'll do some Googling and have a look on RossTech Wiki site
    I've been playing around with VCDS all afternoon and so much to an extent that that battery warning came on!! Whoops!
  1. Avant tailgate and MMI issues - connected?
    By ukandyb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-12-2014, 01:39 AM
  2. yellow steering symbol diagnosis
    By pemac in forum VCDS - Help Requests
    Last Post: 27-04-2011, 10:22 AM
  3. VCDS faults before MMI update
    By piotrek in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-04-2011, 01:13 PM
  4. A8 D3 3.0 tdi 07 with a few problems
    By instrutec in forum A8 - S8 - V8
    Last Post: 16-04-2011, 08:53 PM
  5. Help please - electrical woes after towbar fitting
    By dstanley in forum VCDS - Help Requests
    Last Post: 22-02-2011, 01:03 AM
