Thread: High Level Rear Brake Light
  1. High Level Rear Brake Light
    Apr 2011
    London
    Hi there,
    Apologies if my newbie format is a little off key....
    Garage are trying to relieve me of a cool £100+ to change the High Level Central Rear Brake Light on my 04 A6 2.5TDi Avant.
    Well prepared to have a go myself and buy 2nd hand parts off ebay or wherever.
    Just a few idiot questions:
    1. Can one replace just the bulbs individually, or does the whole light assembly require replacement ?
    2. How and where do I find out the part no. so that I do not purchase the wrong component ?
    3. Where can I find simple instructions about going about this job ?
    Grateful for any advice received !!
    Cheers,
    Marky
  2. Re: High Level Rear Brake Light
    Mar 2008
    High Wycombe
    On the Avant, it's an LED unit. The individual LEDs are not replaceable - you replace the whole unit.
    I think (although I'm not an MOT tester) that it'll pass an MOT unless more than half the LEDs are not working.
    It's quite straightforward to remove:
    -carefully lever out the two red square caps either side of the light.
    -unscrew the bolts.
    -press in the retainers and remove the unit from the tailgate.
    I have no idea how much the light unit should cost, but considering it contains a few resistors and about 10 LEDs, I can't see Audi wanting more than £20 or so for it (That's my complete guess)
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  2. High Level Brake Light
    By seftonbarn in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-08-2010, 02:19 PM
  3. "How To" change a rear light bulb on an A3
    By djgilson in forum Audi
    Last Post: 16-04-2010, 03:54 PM
  4. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  5. re: high level brake light
    By robins1uk in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2009, 11:34 PM
