Thread: 2003 A4 2.5 TDI problem speedo 15mph faster than actual speed?????
  1. 2003 A4 2.5 TDI problem speedo 15mph faster than actual speed?????
    Jan 2011
    Manchester
    Please can someone help me i have recently had a new key cut for my car and they couldnt start it once the key was coded because of the immobiliser kicking in so they removed my file from the clocks and put a new one on (this means nothing to me its what they told me??) now my speedo is 15mph too fast at 30 mph my clocks read 45mph ect ect
    Also i have lost my radio station display from the led display?
    Please can anyone help i do have vag com but its not coming up with any faults.
  2. Re: 2003 A4 2.5 TDI problem speedo 15mph faster than actual speed?????
    Mar 2011
    Kendal Cumbria UK
    If a garage did some work and its got a fault since then it probably something theyve changed, im sure someone on here will be able to tell you what the setting should be but if you posted up a print screen of what your vagcom says about the coding of the instrument cluster it would help them out!
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  3. Re: 2003 A4 2.5 TDI problem speedo 15mph faster than actual speed?????
    Jan 2011
    Manchester
    I will do that tomorrow pal thanks for your help.
  1. Audi A4 2.5 TDI intermittent jerking problem
    By SAJ4D in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-01-2010, 03:38 PM
  2. Replies: 0
    Last Post: 03-12-2005, 07:54 PM
  3. New Audi A4 Cabriolet Range Update Bulletin
    Last Post: 09-11-2005, 08:37 PM
  4. New Audi A4 Cabriolet 2.0 TDI Ticks all the Boxes
    Last Post: 09-10-2005, 12:37 PM
  5. New Audi A4 raises stakes in the compact executive class
    Last Post: 13-09-2004, 07:51 PM
