Thread: TIP: Window Regulator (replacing cable)
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: TIP: Window Regulator (replacing cable)
    Aug 2007
    Cork, Ireland
    UPDATE:
    Don't bother replace the cable. Mine broke again after 15 months. The proper kit just requires 4 rivits to attach it to the internal frame. much easier!
    4 Audi's or is it 4 Audi?
    02 - A6 Avant 1.9 TDi 130 Sport
    01 - A4 Avant 1.8T Sport
    98 - A4 Avant 1.8 SE - Bye bye Bluey
    92 - 80 Saloon 2.0 - My first love (for 10 years)
  2. Re: TIP: Window Regulator (replacing cable)
    Jun 2013
    Quote Originally Posted by midge6 View Post
    I repaired my driver’s window about a year ago and it’s been fine since. If we’re talking about tips, this is the way I did it, after removing window sub-frame as above and installing the new cable, I compressed the spring and clamped it using a small vice grip on a blunt small bolt placed in the hole of the white nylon piece (See Win 1) on both sides of the motor housing (Win 2 has no tension). This effectively locked the cable under tension and made it reasonably easy to thread it around all the rollers. I think that it’s well known that the new clips are pink and are supposed to be stronger than the old blue ones. The ones that came in the kit I bought off EBay were pink but they were rubbish, also the Nylon spool didn’t fit. It wasn’t a problem for me as the cable was ok and I didn’t need the other bits. I have now got a spare cable only, just in case the passenger door window fails. The other tip I would add is to make sure when re-routing the cable that you put some kind of cushioning around it where it’s likely to rattle against the frame – you’ll see the old cable has it built in to the cable cover (Top of Win 2).
    Hope this helps someone.
    For me those photos look like passengers side which ive repaired last year but it looks like driver side has got two separate cables and sliders are different to so the one from ebay doesnt work for me. Can anyone tell me if the cables from passenger and driver side are the same lenght and the led is placed at the same distance?
  3. Re: TIP: Window Regulator (replacing cable)
    Jun 2013
    Ok. Looks like someone installed kit from newer version of audi a6 ;/
  4. Re: TIP: Window Regulator (replacing cable)
    Jan 2017
    London England
    does anyone know if there are different cable lengths? I bought one from e.bay that appears too long.!
  1. Sharan 1.8 Carat Gear Change Cables
    By antells in forum Touran - Sharan - Caravelle
    Last Post: 16-05-2012, 02:39 PM
  2. How To Fitting a Dension Gateway (100) to an A4 B6 / B7
    By toff in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-05-2011, 10:08 PM
  3. Replies: 1
    Last Post: 20-12-2009, 03:18 AM
  4. Replies: 2
    Last Post: 05-11-2007, 01:59 PM
  5. Elec Window Cable snapped
    By Timbo in forum Archive posts
    Last Post: 20-07-2007, 10:14 PM
