Thread: Only passenger side blows hot air
Results 1 to 10 of 15
Hybrid View
  1. Only passenger side blows hot air
    Jul 2007
    Chester
    Only passenger side blows hot air, drivers side blows only cold air, tried to put temp to high but no change.
    Any idea guys?
    Audi TT 1.8T Quattro 225 - Sold , AUDI A4 1.9 TDI 130 AWX - now
    Oct 2010
    Here And There
    Thr little control arm or motor for the temp flap at the heater box. Good luck lol
  3. Re: Only passenger side blows hot air
    Sep 2008
    chester
    17 Post(s)
    The yellow lever.
  4. Re: Only passenger side blows hot air
    Jul 2007
    Chester
    Quote Originally Posted by nevo View Post
    The yellow lever.
    Nevo, I read a few your posts about this problem, but I don't understand what you mean by yellow lever? Where is it? Is it possible to repair ?
    Thank you,
    Dan
  5. Re: Only passenger side blows hot air
    Southern County Softy
    20 Post(s)
    remove the glovebox and you will see the coloured arms attached to motors at one end and the flaps at the other.
    They can stick, when you can see the arms operate the aircon controls and see if the levers move.
    A4 2.5 tdi QS (mapped)
  6. Re: Only passenger side blows hot air
    Sep 2008
    chester
    17 Post(s)
    As kite says, but I believe its your drivers side so up by the clutch pedal remove the trim to gain access the levers,you will see the motors attached to the levers,I think your problem is the yellow one,disconnect the motor,then push the lever by hand,see if you get heat,the report back,its ok to run without the motors.
  1. Question One for the experts, air bag warning ligh and fault codes
    By tony g in forum Golf MK4 - 1999 - 2004
    Last Post: 27-12-2009, 03:28 PM
  2. Passenger side climate control blowing hot, drivers side ok
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 13-12-2009, 10:44 PM
  3. Passenger side fog light - GT TDI PD 130
    By bpunkgttdipd10 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-08-2009, 06:04 PM
  4. Drivers side heater/cooler only blows hot!
    By beddo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-04-2009, 09:57 AM
