Thread: relay identification
  1. relay identification
    Mar 2011
    can anyone tell me what relays are for what plz any pics even better
  2. Re: relay identification
    Sep 2007
    stone,staffordshire
    ok dude,
    a relay is a switch.
    in cars there are circuts that pull quite a lot of current. and to switch quite a lot of current you need a switch with bigger contacts than you would need to switch a small amount of current. ie , a bit switch for a lot of power , a small switch will do for a small amount of power.
    lots of the controls on your car , buttons you press or operate , or sensors on the engine need wiring. and you want the smallest amount of wiring you can get away with ( to save weight and manufacturing costs ) so the car has lots of small wiring to control stuff. so when you turn your head lights on , they pull quite a lot of power, so the wiring on the switch you press/ turn or whatever to turn your lights in actually turn a relay on, which operate your lights.
    a basic relay will normally have 4 contacts.
    1 will be a earth connection
    1 will be the live feed from your switch
    1 will be a live connection from the + of the battery
    1 will the wire going to the live feed to your headlights.
    how they work is , they have a big contact in them ( switch contact )
    and that is switched on by a electric coil, which makes a magnet effect happen and a small bit of metal is pulled by the magnet effect and that closes the contacts, when the power is turned off to the coil a spring pushes the contacts apart.
    the coil is permantly earthed, you switch the live to the coil ( very small amount of power needed so small buttons and wiring needed ) and the relay carries the power to big stuff.
    bet you wish you never asked!
    well me anyways
  3. Re: relay identification
    Apr 2009
    Quote Originally Posted by mrjolly View Post
    well me anyways
    What a great answer, now..... what was the question
    Regards
    Jim
  4. Re: relay identification
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    would hate to mark eez exam paper ! Bless `im !
    Alan.
    VW T6 150 DSG Camper £££
  1. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  2. Intermittent stalling - cured - fuel pump relay
    By well oiled in forum Polo - Derby - Lupo - Fox
    Last Post: 16-02-2010, 04:11 PM
  3. "How To" The FAQ & How To Thread
    By Ben in forum General
  4. Is Relay 267 for Climatronic AirCon
    By wicklah in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-05-2008, 08:04 PM
  5. Fuel Pump Relay Earth Fault
    By kjopen in forum Golf MK3 - 1993 - 1999
    Last Post: 13-03-2008, 10:56 PM
