Thread: G201 Brake Pressure Sensor
  1. G201 Brake Pressure Sensor
    Aug 2007
    Midlands, Uk.
    I'm hoping someone can please help with this problem!!
    Three lights, the suspension, stability control and ABS warning lights all came on the other day.
    VCDS showed up "G201 Brake Pressure Sensor - Intermittant", I know this is part of the ESP pump and cannot be bought seperately (and is £500 ish).
    However, I wiggled the wiring etc, and reset all codes (in ABS, Engine and Level Control ECUs) and lamps have gone out. I checked the measuring blocks, brake pressure seemed to increase with pedal pressure. The brake switch bits toggled ok.
    But.... I'm guessing its not going to be long before it happens again.
    Any ideas? Does this have anything to do with the brake pedal switch, or is the G201 sensor failing?
  2. Re: G201 Brake Pressure Sensor
    Jun 2019
    Swindon
    Hi, did you ever get to the bottom of this?
    I'm having a similar issue that continues even after replacing the pump with a refurbished one.
  3. Re: G201 Brake Pressure Sensor
    Aug 2007
    Midlands, Uk.
    Quote Originally Posted by allroad-diaries View Post
    I never did find out, the car was written off when someone slammed into the back of it, still miss that car!
    I’m convinced it is something to do with the brake pedal switch, ie. pressure is detected by G201 but the switch says pedal is not pressed or vice versa if u see what I mean! I think there are two circuits to the switch, so doesn’t mean ur brake lights aren’t working. It’s worth a check. Also worth checking with user “crasher”
  4. Re: G201 Brake Pressure Sensor
    Jun 2019
    Swindon
    I have ordered a new switch, £20 and simple to swap so may as well tick that one off the list.
    Thanks for the reply.
  5. Re: G201 Brake Pressure Sensor
    Aug 2007
    Midlands, Uk.
    Great, cheap to try, let me know how it goes!
  6. Re: G201 Brake Pressure Sensor
    134 Post(s)
    2007 Post(s)
    The G201 is the brake system pressure switch, the pedal switch is a combined F and F62.
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  3. Question Occasionally losing brake pressure
    By Gazb in forum Golf MK2 - 1984 - 1992
    Last Post: 09-07-2009, 01:21 PM
  4. Why new ABS Unit if no ABS warning light?
    By kaygolf in forum Golf MK4 - 1999 - 2004
    Last Post: 23-01-2009, 12:55 AM
  5. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
