Thread: Windscreen wiper fault
  1. Windscreen wiper fault
    May 2007
    St Ives Cornwall
    Got a 99 tdi Sharan....
    The wiper's will only work on the fast setting....
    New switch and complete linkage Fitted last year....
    Tried a new motor and no different, so packed it neatly back in the box and returned it......
    Sparky has got no idears....
    Has anyone else got any idears... I'm desperate....
    mcc
  2. Unhappy
    May 2007
    St Ives Cornwall
    Has no one got any idears ??????
    Please....
    mcc
    Apr 2007
    Kent
    I had a similar problem with my old GTE. Like you, I changed the linkage, motor and relay. But I found out later it wasn't earthed properly. Worth a try.
    Oct 2006
    Sunny slightly hilly Norfolk
    This might sound daft but...... when they are on fast, are they actually going fast or somewhere between slow and fast? I had the same problem on mine and it was the linkage that had seized. You'll need to disconnect the wiper motor and see if you can move the wipers by hand. If they're stiff that is your answer, its cream crackered and a £180 bill for a new one. Oh and its very common as my dealer keeps them in stock. Its easy to change just slightly time consuming.
    2016 VW Tiguan Match Edition (Nimbus Grey) , 09 Ibiza 1.4 SE SC (Nayara Blue), 2014 Leon 1.2 SE (Candy White).
  1. Intermittent windscreen wiper problems
    By madcarew in forum Archive posts
    Last Post: 24-01-2008, 03:29 PM
  2. Audi A4 wiper arms - Aero wiper arms?
    By paul46 in forum Archive posts
    Last Post: 08-09-2007, 05:47 PM
  3. Windscreen Wiper Problems
    By dmc911 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2007, 07:59 PM
  4. Bora rear windscreen wiper?
    By jolewis in forum Bora - 1998 - 2005
    Last Post: 03-04-2007, 05:06 PM
  5. MK3 Windscreen
    By thefoolmccool in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 03-11-2006, 09:38 AM
