Thread: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
Results 1 to 10 of 16
  1. 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Feb 2009
    Worcester
    Just bought a 2000X A4 2.5TDi V6 Quattro Avant, with good spec, in pretty decent condition, and am reasonably happy with it. Just got a couple of small issues I want to hurry up and sort out though, which I need some help with.
    1. The front windscreen wipers are rubbish! The slowest wipers I have ever come across, I swear it's like they're off an Original Austin Seven or something! What's going on there, do I need a new wiper motor? Or is it something else? Everything works, it's just they're sooooooooo sloooooow...
    2. The brakes are poor. Have read about the conversions to fit 312mm discs up front instead of the 288's, and can get hold of the parts easily, but will they fit under my standard 16" wheels?
    3. The engine takes a long time to get up to any kind of temperature, and even then the water and engine oil do not go above 80 degrees. Having owned numerous VW's before, all with TDi engines, I am used to them getting up to 90 degrees pretty quickly, but then staying there solid as a rock. Obviously, far better this than overheating and warping the heads or blowing a head gasket, but what's up? Stuck thermostat perhpas? And if so, how much of a job to fix?
    Oh, and anyone know if the upgraded Symphony stereo with in dash CD player and tape deck can be removed, for fitting of a normal DIN sized head unit?
  2. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Jun 2010
    Lincoln, Lincolnshire
    Wipers: Is there anything squeaking when they are on? Try greasing up the joints on the arms near the motor. If not it would be best to have a new motor.
    Brakes: No. They wouldnt. You'll ave to get some bigger wheels. How do you mean the brakes are poor? Do they feel spongy? Might be a good idea to change the pads discs and get some new fluid in there! Use DOT4 or above!
    Temp: Yep thats the thermostat. Fairly simple job an a 1.9tdi. not 100% on yours though. But its a case of drain the radiator undo a few bolts pull the old stat out (get soaked by all the coolant that is stuck behind it) wipe the edge, fit new stat with new seal. Fill the coolant back up with audi standard coolant.
    HU: I have a sony hu in mine, easy to pop out you may need to swap a wire or two round in order to keep the radio and equalizer settings saved too.
    Hope all helps!
    Rich
    Headlight Conversion, 2x8000k HID kits, De-cat downpipe, .216 Nozzles Boost Gauge, Colour changed on climate control and all buttons, LED instrument cluster, LED number plate lights, LED rear/brake lights, Lowered 40mm on SPAX springs. Soon to have GT1749VA
  3. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Feb 2009
    Worcester
    Yeah, there is some squeaking, will get in there with a load of lube to see if that helps first off, if not, will investigate a new motor... Are they expensive?
    You sure 312mm discs wouldn't fit under 16" wheels? iirc all Audi TT's came with 312mm front brakes, and some of the lesser powered cars came on 16" wheels... Or did they have 288mm front brakes?
    As far as what's wrong with my brakes, just no power really, and they fade too easily! Probably do need new discs and pads indeed, but my last car, a B5 Passat, had had the 312mm brake upgrade (on 17" wheels) and the brakes were very strong, and I know it's an easy upgrade.
    So it is the thermostat then, fair enough... What would happen if I don't get it done immediately? Bearing in mind that summer is on its way... Car is due a service anyway in about 7k miles, which I'll probably do by about September/October I reckon, so can it wait til then? Or is it more important than that?
    The Head unit is massive, that was my point, not a standard DIN sized unit. Bit annoyed the original owner upgraded this, as the non upgrade head unit was a normal DIN sized unit iirc! Is there any way I can get it out, and fit my nice Alpine iPod controlling head unit?
  4. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Apr 2009
    Its a wiper-linkage problem http://www.audiworld.com/tech/misc44.shtml
    The stat replacement is a job n' a half, do the timing-belt and water-pump
    at the same time.
    Standard brakes should be sharp, look at discs and pads first.
    Regards
    Jim
  5. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Feb 2009
    Worcester
    Cheers Yaman for that link
    Which makes me now beg another question... Is the wiper mechanism in a B5 VW Passat the same as that in a B5 A4? Cos I have a B5 Passat sat on my drive at home, that I am having to break cos the engine seized in it sadly, and maybe I could just nick the fully functional wiper mechanism out of that?
    How long a job is the thermostat replacement? Was planning on getting cambelt changed at the next service anyway (120k miles), but that's 7000 miles away. How many hours is it to do the whole thing?
  6. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Feb 2010
    Worcestershire UK
    I agree with Jim's comments.We have a 2001 2.5 TDi Avant. The brakes in particular should be very positive, they are on our car.
    However I have encountered problems on our older 1.9 TDi Avant which did lead to reduced braking, and a major repair. Firstly both discs became badly scored. This resulted in squealing and grinding noises under anything but the lightest braking. When the car was being dismantled for investigation of these problems, it rapidly became apparent that there was a need for other new parts. All four calipers had corroded pistons, and all four caliper carriers had seized floating pins, out of a total of eight floating pins, only two wern't seized this had led to uneven and excessive pad wear And all this on a fully main agent serviced car
    I did all the repair work on the car myself (it's not too difficult) This involved replacing all four calipers with reconditioned units, and all the caliper carriers (including pins) I foolishly fitted cheap discs. An utter waste of time and money. They refused to run true and were out of spec on the Test Dial Indicator. I replaced the cheapo discs with genuine Audi parts, which ran true and perfect from the word go. Take my advice and stick to genuine Audi discs. While the car was "in dock" I changed all the flexy hoses.
    That was all done about seven or eight years ago, the car has never given any problems since. It's only had the pads changed twice since the "major overhaul." I do check the brakes on a regular basis (about twice a year the car is only doing a tiny mileage), as those damn floating pins can cause aggro if they arn't greased every now and then. I also have the brake fluid renewed every two years, I know a lot of folks don't bother doing this. I think it's well worth the cost and the peace of mind. Plus it's supposed to be done according to Audi's service schedule.
    Hope this helps.
    Kind Regards.
    Paul.
  7. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Jul 2008
    stoke on trent
    312 conversion should fit under 16's and is well worth doing, really helps with brake fade but as suggested check everything is working as it should first
    thermostat, i drove mine for about 6 months without it going over 70deg didnt seem to do any harm, you can always put it in for belt service early (once youve remortgaged to cover the cost!) parts are very expensive for these engines!
    almost every part of double din centre console is different to single din so you cant just change cage, but i would be very interested in doing a swap (pm sent)
    99 a4 b5 1.8tqs saloon
    99 a4 b5 2.5tdi avant
    90 eunos roadster
    Feb 2009
    Worcester
    Well the brakes are starting to get a bit better, from memory the previous owner did say the car had barely been used in last 3 months or so. I remember they looked a bit glazed and marked when I picked it up... Done a few hard stops now, got a good lungful of brake dust, and the performance seems a lot better. Took the car to have front wheels rebalanced last night, and whilst the wheels were off could see the discs and pads are actually almost new, so no worries there. Definitely still want to upgrade to 312's though at some point...
    Wiper mechanism is doing my head in though, I fear if it rained right now, I'll be walking as it's next to useless! Will have to get it pulled apart asap I think...
  9. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Jun 2010
    My brakes aren't in the best condition, some scoring on the discs an a small lip on the rears but they are still very strong, quite impressive actually! All the brake hoses were changed in 2003 according to the service history.
    as for the wiper linkage, its worth a try if you are breaking the car, if it fits great, if not, its already out so you can flebay it
    Swap your fuel filter for a new one, this will improve your mpg and performance slightly.
  10. Re: 2000 A4 2.5TDi Quattro Avant... A couple of small issues
    Apr 2009
    Quote Originally Posted by mboy View Post
    Well the brakes are starting to get a bit better, from memory the previous owner did say the car had barely been used in last 3 months or so. and whilst the wheels were off could see the discs and pads are actually almost new, so no worries there.
    Wiper mechanism is doing my head in though, Will have to get it pulled apart asap I think...
    You could take the pads out and clean the surfaces with a wire brush, at the same time check the pins as Paul suggests.
    The stiff wipers will eventually burn the motor out, don't know about the
    passat's compatibility.
    The timing belt/water-pump/stat should take 4-5 hours
    Regards
    Jim
  1. Looking to buy a 2000 A4 2.5TDi with issues
    By Bigdogcasa in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-04-2011, 12:27 PM
  2. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  3. AUDI S LINE SPORTS RANGE RAISES ITS GAME
    Last Post: 01-12-2005, 08:52 PM
  4. New Audi A4 Cabriolet Range Update Bulletin
    Last Post: 09-11-2005, 08:37 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
