Thread: A4 RNS-E Upgrade
Results 1 to 10 of 10
Hybrid View
  1. A4 RNS-E Upgrade
    Mar 2011
    Hornchuch, Essex, UK
    Hello people, first thread.
    I have a 2007 Audi A4 S-line with a concert single Din stereo and large climate conttol unit. Is there something that can be done so that I can upgrade to the double Din RNS-E?
    I have done a few searches on the forum and Google but couldnt find any relevant answers.
    many thanks in advance,
    Jon.
  2. Re: A4 RNS-E Upgrade
    May 2008
    Yes you can fit the RNS-E.
    Its been done lots of times. Easy and straightforward.
    You need a RNS-E, Double DIN cage, wiring and antenna adapters, Climate control unit (or you can trim down your exisiting one) and a GPS aerial. Reckon on 2-3 hours to fit the lot if you are taking your time.
    You'll also need access to VAGCOM/VCDS to code it all for full functionality.
  3. Re: A4 RNS-E Upgrade
    Coventry
    Lots on this in this section. I can't believe you failed to find anything
  4. Re: A4 RNS-E Upgrade
    Coventry
    At the time of posting this, the thread below was on page 3 of this section.
    https://www.vwaudiforum.co.uk/forum/s...d.php?t=117436
  5. Re: A4 RNS-E Upgrade
    Mar 2011
    Quote Originally Posted by Ben View Post
    Rather than look through the pages of threads I tried a search instead, obviously didnt use the right key words.
    Thank You!
  6. Re: A4 RNS-E Upgrade
    Mar 2011
    Had a read of the PDF that was in the link provided.
    I'm assuming that it would be possible to fit any double din unit using the same method?
    And I've also read several comments in various threads about having to trim the climate control unit, however in the guide provided ( http://www.pvv.org/~shane/stasj/pics...%20an%20A4.pdf ) It only mentions trimming down part of the ashtray, does this mean the climate control unit stays untouched and im guessing is moved down in the space below?
    Jon
    May 2008
    Quote Originally Posted by chev View Post
    get in touch with OEM retrofits in bradford. they come down to london regulary. tell them AZ from manchester recommended
    Or fit it yourself and save a few hundred quid?!
  1. New Audi A4 2.0TDIe
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-01-2010, 01:28 AM
  2. Ultra-economical audi a4 tdi gets the ‘e’ treatment
    Last Post: 11-07-2009, 08:11 PM
  3. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
  4. Audi A4 range plots a new course
    Last Post: 12-05-2007, 08:34 PM
  5. New Audi A4 Cabriolet 2.0 TDI Ticks all the Boxes
    Last Post: 09-10-2005, 12:37 PM
