Thread: Audi A6 / 100 idle-deceleration problem
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Smile
    Jul 2007
    Quote Originally Posted by s6sputnik View Post
    I think that is where i would look...Is the guy who needs this even looking any more?
    Luther
    Sorry chaps been away for a couple of days. I note what you have said and would say thanks for your thoughts and comments.
    I can confirm the throttle is not computer controlled. I think the cable is okay - when it has been playing up and idling fast, I've pulled on the cable and even the connection at the throttle body and it hasn't had an effect.
    After the throttle body was cleaned, the car ran perfectly for two weeks and then the problem just reoccurred. I suspect it is something to do with an intermittent connection or component by the way it happens. Despite having 244k on the clock, the engine runs fine and has plenty of power apart from the idle problem. It still returns 30 - 32 mpg which it did when I purchased it 10 years ago with 64k on the clock. As you see, I get around!
    Thanks once again.
    Jul 2007
    South Africa
    On a '94 with a small 6? Are you sure? My S6 (same body style different motor) does idle differently when the A/C is on. And you also feel and see it when the compressor comes on.
    FWIW I just checked...Without A/C idle is about 875rpm with A/C running 950rpm so either my car is different than his or my car is sick.
    Howzit Sputnk
    I drive an A6 94 model 2.6e V6 Avant Audi and when I switch on a/c the engine sounds very loud and the idle increases so to say i can feel a vibration on my accelerator pedal.
    Do u think this is normal
    thank u
  3. Re: Audi A6 / 100 idle-deceleration problem
    Jul 2007
    I have exactly the same simptoms with my 1997 Avant A6. While this problem occured I switched the ignition off while driving and restarted the car-problem gone for time being. I think it has something to do with a electrical fault somewhere, even sometimes the sunroof does funny things.
  4. Re: Audi A6 / 100 idle-deceleration problem
    Jul 2007
    South Africa
    Yes.. sometimes my sun-roof makes funny noises as if its opening or closing on its own...thanks for the reply...
  5. Re: Audi A6 / 100 idle-deceleration problem
    Austin Texas
    Quote Originally Posted by ladyinred View Post
    Howzit Sputnk
    thank u
    No I don't think it is normal...might you have a bad motor mount? so the additional vibrations from running the A/C can be felt more? Any odd sounds from the A/C unit or is it just loud?
    Have you checked/ replaced the ground to the A/C?
    Shawn Olsen Austin TX ACNA#1616
    //95 S6 RS2 // 02 A6 4.2 // 04 S4
  6. Re: Audi A6 / 100 idle-deceleration problem
    Austin Texas
    I am glad to hear that it is not only in Texas that we have those random automatic sunroof openers .I think there is a contact that gets dirty overtime causing the ghost like opening of the sunroof, however, I have never fixed it on my car yet so I don't know the correct answer sorry.
  1. Audi 100 2.3E Jetronic start and idle problem
    By Stuart Weaver in forum 100 - 200 - Turbo - 100 S4
    Last Post: 24-09-2007, 09:35 AM
  2. 97' A6 rough idle problem
    By plovett26 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-07-2007, 09:31 PM
  3. Audi 100 / A6 idle / deceleration problem
    By wysiwyg73 in forum 100 - 200 - Turbo - 100 S4
    Last Post: 08-07-2007, 09:51 PM
  4. audi 100 idle problem
    By jessicasdad in forum 100 - 200 - Turbo - 100 S4
    Last Post: 19-09-2006, 11:36 AM
  5. 2000 Audi A4 Idle Problem
    By Jaimie129 in forum Chat - Completely Off Topic
    Last Post: 08-08-2006, 03:24 AM
