Thread: Air Conditioning - Not Cold
  1. Air Conditioning - Not Cold
    Nov 2010
    Rickmansworth
    With the recent warmer weather I 've noticed that I can't get the the air con on my 2008 2.0 tdi Avant (purchased in November, since had a new engine - see thread https://www.vwaudiforum.co.uk/forum/s...gine+vibration) to work .
    The heating works, temperature settings all work, but it will not cool below the air temp outside.
    I have read the instructions every which way (Econ off = air con on) but the problem is that when turning the econ off either through the MMI or just pushing the botton, it immediately reverts to 'on' again.
    Does anyone know if this is a function of:
    a) my inability to understand the instructions
    b) some element (refrigerant, recharging) that would be fixed by an air conditioning service of the type that Halfords do (£60-£70)
    c) the compressor's knackered and it's going to cost a lot to fix
    d) none of the above?
    I just have this weary feeling that it's going to be like the new engine saga all over again - have to have a functioning air con, off the Europe later this year and anyway this country is bad enough at the height of Summer without aircon.
    Any advice appreciated.
  2. Re: Air Conditioning - Not Cold
    Southern County Softy
    20 Post(s)
    sounds like it needs a re-gass
    A4 2.5 tdi QS (mapped)
  3. Re: Air Conditioning - Not Cold
    Nov 2010
    Rickmansworth
    Thanks - I'm hoping so - that would be option B above, which I can do with the first MOT which is due next month. Seems odd that it would be dead so early though (less than 3 years), which makes me concerned it might be something more serious.
    Just trying to avoid spending more than I need to do - and running the risk of doing both the cheap option and the expensive option.
  4. Re: Air Conditioning - Not Cold
    Jun 2007
    I would has the system checks for leaks, either via a dye or nitrogen gassing and then, assuming no leaks have the system pumped out and the correct amount of oil added and regassed. I use a local mobile air con guy that quite a few of the garages, including VAG garages use. £60/70 job done. Regards Peter
  5. Re: Air Conditioning - Not Cold
    here, but wish I was there
    Last time I had my previous A6 re gassed was about three years ago, was about GBP65 and they put the dye in too - if there is a problem it can save you a fortune.
    It seems likely it was never done properly when the engine was replaced, or something damaged in the process.
    Good luck and let us know how you get on
    Current - 2002 Audi A6 2.5TDi Avant quattro (loved), 2012 Ford S Max 2.2 tdci Titanium X (serves a purpose), 1983 VW Golf GTI campaign (loved)
    Previous - 2007 Volvo XC90 D5 SE Lux (gone, hated), 2002 Audi A3 1.9TDi Sport quattro (gone, liked and missed), 2011 Audi A6 2.0TDi SE (gone, loved and missed), 2007 Audi A6 2.0TDi SE (gone thankfully), 1999 Audi A6 2.5TDi quattro (gone, loved and missed)
  6. Re: Air Conditioning - Not Cold
    Nov 2010
    Rickmansworth
    Good thought about the engine replacement - I didn't check this specifically, as it was the middle of winter.
    I'll take it next month when I do the MOT and report back.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. your mpg in cold weather?
    By accy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-02-2011, 05:22 PM
  3. Please Help VW Polo Heater Blowing Cold Air
    By VWOXO in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2011, 06:16 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
