Thread: RNS-E Install - climate control template and microphone cable
  1. RNS-E Install - climate control template and microphone cable
    Apr 2010
    Gloucestershire, UK
    I have tested the adapter and everything works perfectly - even has SDS enabled .
    Please could someone trace their double din climate control unit and post it with some dimensions on, this would save me (and probably a few others thinking of the upgrade) some time and worry.
    I have found a thread (on another Audi forum) that relates to the microphone cables that need to be used to get the microphone to work with the RNS-E (it is for an A3). I believe the cable runs down the passenger side (RHD) door pillar and down to the phone prep/bluetooth control box under the passenger seat, is that correct? Is the wire the same green/black combination as the A3 uses? Anyone got any pictures that would show where the cable runs and where to add the necessary wiring?
    Many thanks
  2. Re: RNS-E Install - climate control template and microphone cable
    Apr 2010
    Gloucestershire, UK
    Anybody???
  3. Re: RNS-E Install - climate control template and microphone cable
    Coventry
    To properly trace round the cc unit it will need removing. Easy enough but probably not for a week night.
