Thread: Running cable from Engine bay to cabin (Thru firewall)
  1. Running cable from Engine bay to cabin (Thru firewall)
    May 2007
    I want to run a cable from my grille to the glove compartment. I don't have any gloves, so I thought I'd put a hard drive video recorder in it and put a small camera in the grille.
    I have a 2003 S4. Ideally I would like to push a phono cable through the firewall without having to drill it. Any one know of any available holes already there and how to get ot them?
    Alternatively, is there anywhere that I could drill safely? These cars seem so technical I'm half expecting every body panel to be linked to a printed circuit board.
    Any advice????
    Apr 2007
    Hampshire
    There will be several existing holes through the firewall utilised by various wiring loom branches. They're normally pretty full already but you normally can fit a cable through the grommit, doubt you'd get a phono plug through though, you may need to cut the wire & re-join it once you've poked the cable through. There's not a lot of room at the back of the engine bay but have a look from on tip for any cabling going through the firewall near the battery, if not you'll need to get underneath the car and look from there. Have fun, an interesting idea!!
    '53 Smart Roadster Coupe - So much fun, so little cost to run!!
    '03 Kawasaki ZX6R B1H - Currently off the road due to binning it on the M1!
    '02 A4 3.0 Quattro Sport - Gone but missed daily!
  1. indicator failure whilst engine is running
    By rian p in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2015, 03:26 PM
  2. Engine Running Hot
    By Hynes in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-05-2007, 12:53 PM
  3. Engine smell in cabin
    By paulprd in forum Polo - Derby - Lupo - Fox
    Last Post: 19-04-2007, 05:29 PM
  4. VW 1997 2.0L GTI engine running problem
    By svenandnancy in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-01-2007, 12:48 AM
  5. golf mark 4 engine running problem
    By tyce in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-10-2006, 08:41 PM
