Thread: Petrol In Diesel Engine Opinion needed
Results 1 to 10 of 13
  1. Petrol In Diesel Engine Opinion needed
    Flitwick
    Hello there all, I am in need of some help.
    My dads girl friend has put petrol in his TDI Passat fortunatley she put in about 5 Litters (£7 worth at 135.9p per litter) they was out driving and the car conked out on them (engine just died) My dad went over there got the car started and drove it home about 3-4 miles. It died on him a couple of times.
    This morning I went there with VCDS no fault codes have been logged.
    I did start the car it ran with a bit of smoke and seem to idel ok.
    I want to know will it be ok if we cleand out/renewed the fuel filter and filled up the tank with Primiam Diesel the gauge shows just above the red section.
    The car in questian is a 2004 Passat 1.9 TDI AWX engine with 89k miles on.
    Any idears welcome.
    He is prepared to empty the tank if we have to.
    Also is the damage already been done with them driving it on a mix of petrol/diesel.
    Thanks and sorry for the long post.
    Regards Steve.
    Steve
    2014 Passat Estate
    Executive Style
    2.0 TDI Bluemotion
    Tungsten Silver
  2. Re: Petrol In Diesel Engine Opinion needed
    Apr 2009
    Its all about the % of petrol in the diesel, opinions differ but from what
    you say it seems there is around 50% mixture (a gallon of each?),
    which is dangerously high. If that is true then don't start it till you
    drain the tank and drain and replace the filter, then half-fill the tank.
    Regards
    Jim
  3. Re: Petrol In Diesel Engine Opinion needed
    Jun 2006
    UK, Mids
    Just fill the tank with jerry can to about 1/4 and then drive gently to the petrol station and fill right up.
    It is also a good idea to add two stroke oil to the fuel. Only a small amount. Maybe 1/4 of a bottle to a whole tank.
    Audi A8 - 2015 - 3.0TDI
  4. Re: Petrol In Diesel Engine Opinion needed
    Flitwick
    Thank you snapdragon I was thinking of some kind of oil to put with it. Do you think that this will have any effect to the injector pump at all?
    Steve
    2014 Passat Estate
    Executive Style
    2.0 TDI Bluemotion
    Tungsten Silver
  5. Re: Petrol In Diesel Engine Opinion needed
    Flitwick
    Thanks for the reply Jim Hmm Like you say its a very high mixture even with approximatley 50 Litters of diesel do you think that he will get away with this or would you drain the tank any way.
    I think that may be the way to go. I think I will start searching how to remove the fuel tank.
    Thanks again. Steve
    Steve
    2014 Passat Estate
    Executive Style
    2.0 TDI Bluemotion
    Tungsten Silver
  6. Re: Petrol In Diesel Engine Opinion needed
    Apr 2009
    Since there's not much in it, can you not drain it by taking
    the feed off the filter (into a large coke bottle) and switch the
    ignition on?
    Regards
    Jim
    Edit; oops, no lift-pump in a PD sorry. You might get away with
    just filling it. The choice is yours.
  7. Re: Petrol In Diesel Engine Opinion needed
    Apr 2009
    Hi Steve. Did the same one day,I had put 6 litres petrol into my Polo tdi.
    I just filled the tank up with diesel and drove away. Spoke to a mechanic at the garage and he said that as long as the car is topped up asap (pref diluting it with a jerry can first in your case) to get you back to the pump then you should be ok. He reckoned that no more than 20% of the tank could have petrol in it as long as it was topped up before it
    Although it was in a different car i'd assume the principle is the same.
  8. Re: Petrol In Diesel Engine Opinion needed
    Flitwick
    Quote Originally Posted by yaman View Post
    ignition on?
    Regards
    Jim
    Thats a good idea did not think of that. Should be able to get a 25 Litter drum from somewhere and put it in that and see if the recycling centre can take it in. or even a petrol station.
    Thanks again.
    Steve.
    Steve
    2014 Passat Estate
    Executive Style
    2.0 TDI Bluemotion
    Tungsten Silver
  9. Re: Petrol In Diesel Engine Opinion needed
    Flitwick
    Quote Originally Posted by davemidd View Post
    Thank you for your reply this is so far has been very 50/50 I am not sure what way to go yet but i have not got to make that desision thankfully.
    I personley would just fill it right up and drive it arround carfully. But my dad was talking about emptying the tank. I think that he will drain it as that is what he wanted to do in the first place and since its so easy to do as Jim sergested and since there is not much fuel in there.
    Thank you for your reply Steve
    Steve
    2014 Passat Estate
    Executive Style
    2.0 TDI Bluemotion
    Tungsten Silver
  10. Re: Petrol In Diesel Engine Opinion needed
    Apr 2009
    Quote Originally Posted by Steven715 View Post
    RE-READ POST 6!!
    Regards
    JIm
  1. Please Help Do You have VCDS
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2014, 11:17 AM
  2. oil warning signal
    By ger83 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2009, 07:20 PM
  3. whats faster petrol or diesel
    By rob160 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-08-2009, 02:28 PM
  4. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
